Resin Tank LT damage and wear (Form 2)
The lifetime of a Resin Tank LT varies depending on print practices, resin type, and layer thickness. To prevent damage to the elastic layer, orient and support models properly in PreForm. Use only the recommended tools and cleaning instructions.
Note:
The sample images below show the elastic layer on Resin Tanks LT as viewed through the underside of the acrylic tank window.
alt text
Scratches
Slight scratches in the film-coated layer normally appear after use and should not affect print quality.
alt text
If scratches are heavy or affect print quality, use PreForm to move prints away from the scratched area or replace the tank.
Indentations
alt text
Gouges and punctures
A gouged or punctured tank requires replacement. Gouges and punctures in the film bend light and prevent the laser from curing resin properly. They may also allow resin to leak into and cure under the film, which can lead to further damage.
alt text
alt text
Common causes for gouges and punctures include:
  • using a sharp tool inside the tank
  • using excessive force to scrape the tank
  • print failures
Rippled surface
Rigid Resin and Grey Pro Resin are high performance materials that can accelerate wear on the resin tank. Ripples usually appear in Resin Tanks LT after use with 1–2 L of these two resins.
While the rate of wear depends on a variety of print factors, ripples typically begin to form at the edges of the tank and spread toward the center. Ripples in the film-coated elastic layer may cause parts to print with a wavy or rippled surface on smooth or flat areas.
alt text
Rippled surface on the film-coated elastic layer on Resin Tank LT.
If ripples on the tank bottom affect print quality, either use the Layout tool in PreForm to print around the affected print area or replace the tank.
Best practices
Follow these best practices to maximize the lifetime of your Resin Tank LT:
  • Inspect the tank frequently for debris.
  • Clean up failed prints and resin spills immediately.
  • Use tools with rounded edges to inspect the resin tank and to remove failed prints.
  • Print on different areas of the build platform to distribute wear evenly across the tank surface.
  • Orient parts at an angle to reduce the risk of print failures and damage.
  • Parts with larger cross-sections and fewer layers increase tank lifetime but decrease the number of printed parts that fit on a single build platform.
  • Parts with smaller cross-sections and more layers decrease tank lifetime but increase the number of printed parts that fit on a single build platform.
  • Use only Formlabs recommended cleaning instructions to avoid damaging the tank.
For assistance with wear or damage beyond the examples listed above, contact Formlabs Support. Specify the resin type and include clear, well-lit images of the elastic layer.
Next: Replacing standard resin tanks and Resin Tanks LT
