Glossario del prodotto (Fuse Sift)
Consiglio:
Visita la pagina Fuse Tour interattivo della Fuse Sift per una vista 3D di molti dei componenti dettagliate di seguito.
Area di lavoro e componenti esterni
ItemDescriptionImage
HoodPrevents powder and debris from leaving the Fuse Sift’s workspace.
Control panelA touchscreen and physical control panel for interfacing with the Fuse Sift.
VacuumThe vacuum hose and power cord plug into ports on the side of the Fuse Sift, allowing the vacuum to be controlled via the Fuse Sift's touchscreen or control panel.
Vacuum hoseConnected to the external vacuum for cleaning the Fuse 1 and Fuse Sift after use.
Tool shelfStorage for break-out tools and brushes.
Parts basketStorage container for extracted parts while processing a cake.
VentA fan pulls dispersed powder into a filter, preventing plumes from leaving the workspace.
LightThe light illuminates the workspace while extracting and cleaning printed parts.
SifterThe sifter agitates and breaks up clumps of unsintered powder from previous prints before it is recaptured for reuse.
Surface grateProtective grate covering the sifter.Surface grate
Powder catchRemovable tray for catching loose powder.Powder catch
MixerThe mixer spins a filled powder cartridge to ensure a homogeneous distribution of fresh and used powder.
Camera di stampa
Build chamberAn interchangeable component of the Fuse 1 that contains the print bed, heaters and temperature sensors, and encapsulates the sintered parts and loose powder from a print. The accompanying plug allows the Fuse 1 and Fuse Sift to monitor the build chamber, and differentiate one build chamber from another.
Build chamber enclosureArea for housing the build chamber with prints ready to be ejected. Build chamber enclosure
Build chamber portAccess port for the cooled powder cake to enter the workspace.Build chamber port
Build chamber latchSecures the build chamber.Build chamber latch
Build chamber socketConnects the build chamber’s plug.Build chamber socket
Manipolazione della polvere
Sifter meshThe sifter mesh filters reusable powder from unusable powder.Sifter mesh
Fresh powder hopperThe fresh powder hopper holds unused powder for dispensing into a powder cartridge.
Used powder hopperThe used powder hopper holds recaptured powder for dispensing into a powder cartridge.
Fresh powder hopper lidAccess point for filling the fresh powder hopper.Fresh powder hopper lid
Doser assemblyThe doser assembly dispenses fresh and used powder into a powder cartridge in a ratio matching the selected refresh rate.Doser assembly
Cartridge drawerHolds the powder cartridge while it is being filled with powder. Weight sensors in the cartridge drawer ensure that the cartridge is filled properly.
Scheda madre e componenti elettronici
MotherboardThe main circuitry through which all systems in the machine communicate.
Power supplyThe Fuse Sift requires a 230 VAC (50 Hz), 7.5 A power supply (EU) or 120 VAC (60 Hz), 15 A power supply (US) for nominal operation.Power supply
Wi-Fi antennaThe Wi-Fi antenna enables the Fuse Sift's wireless connectivity. The antenna is connected to the machine's motherboard.Wi-Fi antenna
Ethernet and USB portsThe Fuse Sift can connect to a network via Ethernet or to a computer via USB. These ports are connected to the motherboard and can be accessed from the back of the machine.
Pannello di controllo
TouchscreenInteractive touchscreen for controlling subsystems and settings of the Fuse Sift.
Physical controls
  • Bed chamber controls: physical control for raising and lowering the print bed into and out of the workspace
  • Sift button: physical control for starting and stopping the sifter
  • Vac button: physical control for turning on and off the workspace light and vent
  • Vacuum button: physical control for turning on and off the auxiliary vacuum
Cartuccia di polvere
ElementoDescrizioneImmagine
Cartuccia di polvereIl contenitore in cui la polvere SLS viene miscelata e trasportata dalla Fuse Sift al serbatoio della stampante.Powder cartridge
Alette della cartucciaDue staffe per il bloccaggio della cartuccia al miscelatore.Cartridge wings
Valvola della cartucciaL'apertura principale per il riempimento e il deposito della polvere.Cartridge valve
Lama della valvolaServe per chiudere e aprire la valvola della cartuccia.Valve knife
ManigliePer tenere e sollevare la cartuccia.Handles
Miscelatore
Piattaforma rotante del miscelatoreLa faccia esterna del miscelatore che ruota con la cartuccia.Mixer turntable
Linguette di chiusuraDue linguette a molla per fissare la cartuccia nel miscelatore.Locking tabs
Accoppiatori delle alette delle cartucceDue staffe che guidano le alette della cartuccia in posizione. Cartridge wing couplers
