Changing your printer's display name (Form 4 and Form 4L generation)
Starting with firmware version 1.14.0 or later, you can set a custom display name for your Form 4 or Form 4L generation printer, making it easier to identify the machine. Once set, the custom name appears in PreForm, on Dashboard, and on the printer’s touchscreen.
Note:
Changing the display name of your Form 4 or Form 4L generation printer does not change the serial name of the printer. Read this article for more information on how to find your printer’s serial name
  1. On the printer's touchscreen, tap Settings > General > About this printer. By default, the display name is the last part of your printer’s serial name (e.g., AdjectiveAnimal, without the printer designation).
Settings menu on a Form 4 printer
  1. Tap Display name. The Enter display name screen appears.
  2. Using the onscreen keyboard, enter a custom name up to 20 characters in length.
Entering a custom display name on a Form 4 printer
  1. Tap the check mark. The printer saves the display name and displays the message Display name set successfully. Once set, the display name appears in the status bar at the top of the touchscreen.
Form 4 printer with a custom display name.
Form 4 with a custom display name set in PreForm
Tip:
You can also see your printer’s display name in PreForm and Dashboard. You may need to restart PreForm for the change to be visible.
