Downloading and sending diagnostic logs
Formlabs printers and accessories maintain diagnostic logs to provide detailed information about the machine’s functionality. Include these diagnostic logs with other relevant observations and details when contacting Formlabs Support or your authorized reseller to speed up resolution.
If your machine is connected to the internet and logging is enabled, it will automatically upload diagnostic logs on a regular basis. To enable logging on your machine:
  • Form 2, Form 3, Form 3L, and Fuse 1 generation printers: Tap Settings > Connectivity > Dashboard Logging.
  • Form 4 and Form 4L generation printers: Tap Settings > Analytics > Share print logs.
  • Fuse X1 printers: Tap Settings > Analytics > Share print logs.
  • Fuse Sift: Tap Settings > Connectivity > Dashboard Logging.
  • Fuse Blast: Tap Settings > Connectivity > Device Logging.
To ensure that Formlabs Support has access to the latest data, you can also manually send diagnostic logs to Formlabs via the touchscreen. If your machine is not connected to the internet, you can download the logs file to your computer to send to Formlabs.
To download or send diagnostic logs, follow the instructions for your machine below.
Form 4/Form 4L
  1. Tap the gear icon on the bottom left of the printer’s home screen. The Settings screen appears.
  2. Tap Support. The Support screen appears.
  3. Tap Send diagnostic information. A confirmation message to upload diagnostic information appears.
  4. Tap Upload to start the upload. A confirmation message appears when the upload is complete.
Form 3/Form 3L
  1. Tap the wrench icon on the bottom left of the printer's home screen. The Settings screen appears.
  2. Tap System. The System screen appears.
  3. Tap Upload Diagnostic Info. A confirmation message to upload diagnostic information appears.
  4. Tap Next to start the upload. A confirmation message appears when the upload is complete.
  5. If the printer displays an error message indicating that it cannot upload the logs, there may not be enough storage space on the printer for the upload. Delete print jobs from the Queue to clear enough storage space to upload the diagnostic logs.
  6. Restart the printer and try again.
Form 2
  1. Tap the printer icon on the printer's home screen. The My Printer screen appears.
  2. Tap Settings. The Settings screen appears.
  3. Tap Printer Info. The Printer Info screen appears.
  4. Tap Upload Diagnostic Info. A confirmation message to upload diagnostic information appears.
  5. Tap Continue to start the upload. A confirmation message appears when the upload is complete.
  6. If the printer displays an error message indicating that it cannot upload the logs, there may not be enough storage space on the printer for the upload. Delete print jobs from the Queue to clear enough storage space to upload the diagnostic logs.
  7. Restart the printer and try again.
Fuse 1 generation
  1. Tap the gear icon on the bottom left of the printer's home screen. The Settings screen appears.
  5. If the printer displays an error message indicating that it cannot upload the logs, there may not be enough storage space on the printer for the upload. Delete print jobs from the Print History to clear enough storage space to upload the diagnostic logs.
Fuse X1
  1. Tap the gear icon on the top right of the printer’s home screen. The Settings screen appears.
Fuse Sift
  1. Tap the wrench icon on the bottom left of the Fuse Sift’s home screen. The Settings screen appears.
Fuse Blast
  1. Tap the gear icon on the bottom left of the Fuse Sift’s home screen. The Settings screen appears.
PreForm
To access the PreForm log file:
  1. Open PreForm.
  2. Click Help > Open Log Directory. The PreForm logs folder opens.
  3. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
To manually access the PreForm log file:
macOS
To download the PreForm log file on macOS:
  1. Hold the Option key on your keyboard, and click the Go menu in the Finder menu bar at the top of the screen.
  2. Select Library from the Go menu (while holding down the Option key) to access the hidden folder.
  3. In Library, select the Application Support folder.
  4. In Applications Support, navigate to /Formlabs/PreForm/Logs/log.txt.
  5. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
Windows
To download the PreForm log file on Windows:
  1. Press the Windows key + E on your keyboard to open the File Explorer.
  2. Follow the Windows instructions to show hidden files in the File Explorer.
  3. In File Explorer, navigate to C:\Users\USERNAME\AppData\Local\Formlabs\PreForm\Logs, replacing USERNAME with your local user name.
    • If you're not sure what your user name is, navigate to C:\Users to view a list of user names in use on the computer.
  4. Attach the log.txt file when contacting Formlabs Support or your authorized reseller.
Downloading printer diagnostic logs through PreForm
If your machine is not or cannot be connected to the internet, you can still download logs to share with Formlabs via PreForm.
  1. Open PreForm.
  2. Click Edit Job Setup. The Job Setup window opens.
  3. Select the printer’s serial name.
  4. Click Download Logs. A confirmation window appears.
  5. Click Browse to download the diagnostic logs to a preferred location on your computer.
  6. Click OK. The diagnostic logs save and appear in the encrypted FORMLOGS format.
  7. Attach the file when contacting Formlabs Support or your authorized reseller.
  8. If PreForm displays the message ERROR_BAD_STATE, there may not be enough storage space on the printer for the upload. Delete print jobs from the Queue to clear enough storage space to upload the logs.
  9. Restart the printer and try again.
Downloading accessory diagnostic logs through PreForm
  1. Open PreForm.
  2. Click File > Accessories in the menu bar. The Accessory List window appears.
  3. Select the machine’s serial name. The Device Details window for the selected machine appears.
