Required supplies:
- Replacement RFID board (RP-F3L-RFID-01)
Third-party:
- 2.5 mm hex driver (flat-end)
- 3 mm hex driver (must have a 90º head)
- T10 Torx driver
Fuse 1 generation printers use an RFID reader to interact with powder credit cards and register powder credits. On Fuse 1 printers, this RFID reader is located in the upper cooling shroud, near the IR sensor. A faulty or malfunctioning RFID board will prevent the printer from registering or moving powder credits and could lead to other unexpected errors.
Use this guide to replace the RFID board on a Fuse 1 printer.
Required supplies:
Third-party:
Estimated time: 45–60 minutes
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the RFID board.
Step 1: Prepare the workspace
Step 2: Unplug the printer
Danger:
Removing the top panel
Overview: Remove the top panel to access the interior of the printer.
Step 1: Remove the top panel screws
Using a 2.5 mm hex driver, remove the 26 6 mm M4 countersunk screws securing the top panel to the printer:
Set the screws aside.
Step 2: Remove the top panel
Lift the top panel off of the printer by grabbing the IR sensor door and the rear-most edge. Set the top panel aside.
Removing the upper cooling shroud
Overview: Remove the upper cooling shroud to access the RFID board.
Step 1: Remove the IR sensor
Open the access door to the IR sensor panel, located on top of the printer next to the hopper. Lift the IR sensor and disconnect the cable from it. Set the IR sensor aside on a flat surface with the sensor window facing up. Feed the IR sensor’s cable down through the plastic shroud.
Step 2: Remove the upper cooling shroud screws
Using a 3 mm hex driver, loosen and remove the four 8 mm M4 socket head screws securing the upper cooling shroud to the printer. Do not yet separate the upper cooling shroud from the printer.
Step 3: Lift the upper cooling shroud
Gently lift up but do not separate the front edge of the plastic shroud from the top of the printer so that the cables attached to the shroud can be accessed.
Take care when lifting the plastic shroud so as to not strain the cables attached to it.
Step 4: Unplug the fan cable
Disconnect the fan cable from the connector labeled C047 by squeezing on the plastic latch. Do not pull on the individual wires; only pull on the plastic connector.
Tip:
It may be helpful to have one person hold the plastic shroud while another person unplugs the cables.
Step 5: Unplug the RFID reader
Unplug the RFID reader board cable from the circuit board by gently pulling on the white connector.
Step 6: Remove the upper cooling shroud
Separate the upper cooling shroud from the printer and set it aside.
Replacing the RFID board
Overview: Remove the original RFID board and mount the replacement.
Step 1: Remove the original RFID board
Using a T10 Torx driver, loosen and remove the two screws securing the RFID board to the upper cooling shroud. Set the screws aside. Separate the RFID board from the upper cooling shroud and set it aside for disposal with electronic waste.
Step 2: Mount and secure the replacement RFID board
Position the new RFID board so that the two screw holes just below the connector are aligned with the screw holes on the upper cooling shroud. Thread one T10 Torx screw into both of the screw holes, then use a T10 Torx driver to tighten until snug.
Reinstalling the upper cooling shroud
Overview: After replacing the RFID board, reinstall the upper cooling shroud.
Step 1: Reonnect the RFID reader cable
Hold the upper cooling shroud above the printer and plug the RFID reader cable connector into the RFID board by gently pushing it into the receptacle. The connector will only fit in one orientation.
Step 2: Reconnect the cooling fan
Reconnect the cooling fan connector to the socket labeled C047.
Step 3: Route the IR sensor cable
Position the top cooling shroud by holding it from the front edge so that the cables covered by the shroud can still be accessed. Feed the IR sensor’s Ethernet cable back through the cutout in the top shroud.
Step 5: Mount and secure the upper cooling shroud
Lower the upper cooling shroud on the printer, aligning the four screw holes in the shroud with the corresponding screw holes in the printer frame. Thread one 8 mm M4 socket head screw into each of the screw holes. Using a 3 mm hex driver, tighten until snug.
Step 6: Connect and mount the IR sensor
Inspect the IR sensor lens for debris and clean it if necessary. Attach the ethernet cable to the IR sensor, then place the sensor back into its mount.
Reinstalling the top panel
Overview: After installing the new RFID board, reinstall and secure the top panel.
Step 1: Align the top panel
Lift the top panel and place it on top of the printer. Align the screw holes in the top panel with the corresponding holes in the printer frame.
Step 2: Secure the top panel screws
Thread a 6 mm M4 countersunk screw into each of the 26 marked screw holes in the top panel:
Using a 2.5 mm hex driver, tighten the screws until snug.
Finalizing the repair
Overview: After installing the replacement RFID board, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the repair
Insert a powder credit card (if one is available) and register or transfer powder credit. Contact Formlabs Support or your certified service provider to share the results of the procedure.
