What is the Print Settings Editor?
The Print Settings Editor is a PreForm feature for experienced users to tailor print performance for their exact application. The tool should only be used by advanced users who understand how to modify print parameters and debug any resulting issues. If you have an issue when printing with your custom print settings, Formlabs Support will ask you to revert back to the Formlabs default print setting.
Do not use the Print Settings Editor to troubleshoot issues with your print or prints. If you have an issue, contact Formlabs Support. We will help you identify the root cause of the issue and then provide the appropriate solution.
Formlabs provides optimized and validated print settings for every Formlabs material. Formlabs print settings are designed to balance reliability, speed, quality, and material properties. We strongly recommend starting with Formlabs print settings whenever you’re printing a part for the first time.
Note:
The Print Settings Editor was introduced in PreForm 3.33.0. Keep PreForm updated to access the latest print preparation features.
