Checking the optics of your Fuse X1 printer
Laser light in a Fuse X1 printer passes through multiple windows before reaching and sintering the powder in the build unit. If these windows are not clean or the laser has grown weaker over time, the printer will not function as expected. Your parts may have defects or may fail to print at all.
Formlabs recommends cleaning the printer’s various optical components on a regular basis. You can also print a diagnostic tool and review the results on the printer’s touchscreen to check optical cleanliness and predicted laser power.
Completed optics check print
Running the optics check print
  1. Update PreForm to the latest version.
  2. Update your printer’s firmware to the latest version.
  3. Check that your printer’s hopper is not empty. The optics check is a one-layer print, so it does not require much powder.
  4. Download the appropriate FLZ file for your material from the links below.
  1. Open PreForm and select Job Settings.
  2. In the Job Setup window, make sure the correct printer is selected.
  3. Select Upload Diagnostic Print.
  4. Upload the file from your computer.
Uploading a diagnostic print
  1. On the printer’s touchscreen, tap Settings > Tools > Optics health check. The Optics health check screen appears.
  2. If you have successfully uploaded the optics check print, tap Start. If you have not uploaded the file, the button will be greyed out and unavailable.
  3. Allow the build unit to fully cool per Formlabs recommendations, then clean the single layer of powder on the print bed before your next print.
Starting the Fuse X1 optics health check
Starting the Fuse X1 optics health check print
Fuse X1 optics health check print not uploaded
Checking the results
After the print is complete, use the Diagnostic Prints tool to evaluate the results:
  1. Tap the gear icon. The Settings screen appears.
  2. Tap Tools > Optics health check > History. The Optics health check screen appears, showing a list of completed diagnostic test prints.
  3. Tap the name of the diagnostic print you previously ran. A results window appears showing a photo of the Optical Cleanliness Scan. Compare the photo to the examples below to evaluate the cleanliness of your printer’s optics and determine what you should clean.
  4. Tap Next. A second screen appears showing the calculated Laser Power based off of the test print. If this laser power is under 80% after cleaning and repeating the test print, contact Formlabs Support for additional analysis.
  5. Tap Done to close the results window.
If the scan results do not appear:
  1. Perform a factory reset on your machine by tapping Settings > General > Factory reset and following the on-screen instructions.
  2. Enable Print Image Collection. Tap Settings > System > Print Image Collection > Enable.
  3. Update or reflash your printer’s firmware.
  4. Rerun the test print and check if the results are available.
  5. If the results are still unavailable, upload your printer’s diagnostic logs by tapping Settings > Support > Send diagnostic information and contact Formlabs Support. Formlabs Support can check the optics test print images in the printer logs and help you analyze the result.
Cleaning your printer’s optics
Based on the results of the optics check, clean your printer’s optics before your next print:
Light spots visible on the print image
Optics check showing minor contamination
Light spots around the image indicate relatively minor optical contamination, most likely on the optical cassette. Thoroughly clean the lower laser window.
Unsintered regions
Optics check showing unsintered regions
Larger areas of contamination can lead to chunks of the optics check print pattern not sintering. Thoroughly clean the lower laser window, as you would for more minor contamination. Heavier contamination may also impact laser power calculations, so run the test print again if the calculated laser power was previously low.
Diffuse laser spot and minimal sintering
A diffuse central laser spot and minimal sintering of the test pattern indicates that there could be contamination closer to the laser (i.e., above the lower laser window) diffusing the laser light. Thoroughly clean the lower laser window, as you would for more minor contamination. Heavier contamination may also impact laser power calculations, so run the test print again if the calculated laser power was previously low. If you see similar results, contact Formlabs Support for additional analysis.
Optics check showing a diffuse laser spot
Low laser power
If the tool showed a calculated laser power under 92.5%, clean the lower laser window and rerun the test print. If the laser power is still low, contact Formlabs Support for additional analysis.
