Checking the Form 1+ mirror
The Form 1+ mirrors require special care to maintain functionality. Learn how to properly inspect the mirrors between prints.
Exercise extreme caution when the mirror is exposed. Contact Formlabs Support before you clean your mirror or if you have any questions.
1. Remove the build platform and resin tank
2. Check the mirror for dust and resin
Without the right lighting, some dust or oils on the mirror may be impossible to see. Move your light source around to inspect the mirror at various angles.
Compressed air can cause damage to the mirror if used improperly. To use canned air, bend the straw while holding the can upright. Tilting the canister will expel liquid and will permanently damage the mirror.
Learn more about cleaning the Form 1+ mirror after the inspection steps above. Do not do any additional cleaning without consulting Formlabs Support.
