Firmware downloads and release notes
This article summarizes the changes for each firmware release. Review the PreForm release notes to learn more about the improvements that come with each software release.
For instructions on installing a firmware update to your Formlabs product, view the following articles:
Latest versions
Stay up to date with the latest printer firmware.
Printer Version Number Release Date Download
Fuse 1 Firmware 1.24.2 August 4, 2026 Link
Fuse 1+ 30W Firmware 1.24.2 August 4, 2026 Link
Fuse Sift Firmware 1.7.0 April 24, 2025 Link
Fuse Blast Firmware 1.3.1 July 22, 2025 Link
Form 4B Firmware 1.17.1 September 23, 2026 Link
Form 4 Firmware 1.17.1 September 23, 2026 Link
Form 4L Firmware 1.17.1 September 23, 2026 Link
Form 4BL Firmware 1.17.1 September 23, 2026 Link
Form 3BL Firmware 2.5.6 March 24, 2026 Link
Form 3L Firmware 2.5.6 March 24, 2026 Link
Form Wash L V1
Form Wash L V2
Firmware 1.4.0 March 17, 2026 Link
Form Cure L V1 Firmware 1.3.0 January 28, 2025 Link
Form 3B/Form 3B+ Firmware 2.5.6 March 24, 2026 Link
Form 3/Form 3+ Firmware 2.5.6 March 24, 2026 Link
Form Auto Firmware 2.4.0 March 21, 2024 Link
Form 2 Firmware 1.19.27 May 18, 2023 Link
Form 1+ Firmware 1.40 December 17, 2014 Link
Form Wash V1, Form Wash V2, Form Cure V1, Form Cure V2, and Form Cure L V2 firmware updates are distributed with PreForm rather than as separate downloadable files. The latest firmware versions are:
  • Form Wash V1: 2.1.0
  • Form Wash V2: 2.1.0
  • Form Cure V1: 2.1.0
  • Form Cure V2: 1.3.4
  • Form Cure L V2: 1.2.7
Fuse 1
The following were recommended updates for Fuse 1 printers:
Version What's New Date Download
1.24.2
  • Compatible with PreForm 3.26.0 and later
  • New features:
    • Allow up to a ±10 degree Powder Dosing Offset (previously ±5 degrees) to compensate for more printer-to-printer variation.
August 4, 2026 Link
1.24.1
  • Bug fixes:
    • Diagnostic print evaluation: Fixed a bug that prevented diagnostic prints from being evaluated on some printers and test prints.
March 26, 2026 Link
1.24.0
  • New features:
    • Diagnostic print evaluation: Added a new feature that allows the on-printer evaluation of previously-run diagnostic prints for optical cleanliness, exhaust cleanliness, and laser performance. The prints currently supported for on-printer evaluation are an optics check and Bed Temperature Tuning print. Tap Settings > Tools > Diagnostic Prints to view the list of print jobs. Note that only diagnostic prints run after this firmware was installed are available for analysis.
    • Non-critical sensor faults: The printer shows a QR code linking to support pages when non-critical sensor faults are triggered.
    • Prevent priming with full build chambers: Priming will fail if the build chamber has not been removed since the last completed print, preventing damage to the printer.
  • Bug fixes:
    • Powder card location indicator: All UI screens should now show the powder card at the correct location.
    • Duplicated Error History: Fixed an issue where the entries in the printer's Error History were duplicated.
    • Buffer flipper calibration: Fixed an issue where the flipper calibration could not be performed when the UI language was set to Chinese.
February 23, 2026 Link
Fuse 1+ 30W
The following were recommended updates for Fuse 1+ 30W printers:
1.24.2
  • New features:
August 4, 2026 Link
1.24.1
  • Bug fixes:
March 26, 2026 Link
1.24.0
  • New features:
  • Bug fixes:
Fuse Sift
Note:
Fuse Sift units that have had their motherboard replaced cannot run firmware versions earlier than 1.5.2. Any attempt to roll back the firmware to an older version on a Fuse Sift without its original motherboard will fail to complete.
The following were recommended updates for Fuse Sift powder recovery stations:
1.7.0
  • Improved warning messages during build chamber cooldown.
  • Changed default refresh rate for Nylon 12 Tough Powder from 30% to 20%, matching Formlabs recommendations.
  • Fixed messaging inconsistencies when trying to fill a powder cartridge from an empty hopper.
  • Added workflows for calibrating the doser and mixer after replacement.
April 24, 2025 Link
Fuse Blast
The following were recommended updates for Fuse Blast media blasting cabinets:
1.3.1
  • Compatible with PreForm 3.34.0 and later
  • Bug fixes:
    • Fixed issue preventing new Fuse Blast units from being programmed correctly during production.
July 22, 2025 Link
Form 4B
The following were recommended updates for Form 4B printers:
1.17.1
  • Compatible with PreForm 3.40.1 and later
  • New fatures:
    • Form Mobile App support
      • The Form Mobile App allows you to monitor prints, access the camera view, control the printer remotely, and view timelapses and print history. Register your Form 4 or Form 4L generation to the app through the printer’s touchscreen. Once the printer is registered to the Form Mobile App, it sends data to the app as long as it is able to access the internet.
  • Improvements:
    • Form Mobile
      • Live stream view show now appears faster in the app
      • Support added for push notifications from only my print events instead of getting all events from all users’ printers.
      • Printer now sends the data needed to show resin temperature data
  • Bug fixes:
    • Fixed bug where resin level shown was dropping temporarily while dispensing.
    • Improved behavior related to the printer reconnecting to cloud services after a disconnect.
    • Printer should no longer deduct resin usage from card or cartridge if a printer is printing an Open Materials Mode job and has an Open Materials Mode license.
    • Printer blocked from printing from remote Dashboard by a Cartridge Check warning was not always showing warning on physical touch screen, causing user confusion in Dashboard/Queue about why a printer could not auto-start a job.
    • Mobile app integration: quickly opening and closing a camera live stream from Form Mobile could stop the printer reporting data to the cloud until the printer was rebooted.
1.17.0
  • Improvements:
    • Optimized memory and disk usage
  • Bug fixes:
    • Fixed an issue where the cleaning sheet was unable to print in Open Material Mode.
    • Fixed an issue where the print queue actions had a long latency.
August 18, 2026 Link
1.16.1
  • New features:
    • Mark a print as favorite: You can mark your print as favorite either in the queue or in the history. All favorite items appear in the list on the Favorites tab.
  • Improvements:
    • Split tab view for your print queue and print history: View your past prints in the History tab without needing to scroll through the print queue.
  • Bug fixes:
    • Fixed an issue where the printer would get stuck in a print download loop from Dashboard on a very poor internet connection.
    • Fixed several minor issues on the printer UI, which affected only the interface and were unrelated to print quality.
June 18, 2026 Link
1.15.2
  • Improvements:
    • Disable notification pop-ups using the new configuration menu under Settings > Configuration > Notifications and alerts. You can control whether you are reminded to clean your build platform, lock the mixer, open the resin cartridge vent cap, and clean the resin tank after a failed print.
  • Bug fixes:
    • Fixed an issue on Form 4L generation printers where, when using a Resin Pumping System in one cartridge slot and a regular resin cartridge in the other, the printer would not automatically switch to use the resin cartridge if the 5 L jug for the Resin Pumping System ran dry.
    • Fixed an issue where resin dispensing stopped when the resin tank overfill warning was ignored.
May 26, 2026 Link
1.15.1
  • Bug fixes:
    • Fixed an issue where the UI shows duplicated Fit Tuning entries
    • Fixed issue with job names written with Hebrew characters
    • Fixed an issue where the printer would lose communication with Dashboard when using an unused resin tank
March 23, 2026 Link
1.15.0
  • New features:
    • Custom cleaning sheet time: When printing a cleaning sheet, you can set a custom print time for each material.
    • High Volume Manufacturing mode: With High Volume Manufacturing mode enabled, the printer keeps the resin tank full, heated, and mixed between prints, helping high-volume users reduce preprint times and stay ready to print.
  • Improvements:
    • The printer now says Downloading job instead of Uploading job when a job is being transferred from PreForm or Dashboard to the printer.
    • The screen now shows the resin tank cleaning workflow when a tank with uncleaned debris is inserted to the printer.
  • Bug fixes:
    • Fixed an issue where tapping the touchscreen to wake the printer also registered as interaction with the touchscreen
    • Fixed the text on the drain cartridge and load cell calibration screens on Form 4L generation printers
    • Fixed missing log upload confirmation after manual log upload
February 2, 2026 Link
Form 4
The following were recommended updates for Form 4 printers:
1.17.1
  • New fatures:
  • Improvements:
    • Form Mobile
  • Bug fixes:
1.17.0
  • Improvements:
  • Bug fixes:
1.16.1
  • New features:
  • Improvements:
  • Bug fixes:
June 18, 2026 Link
1.15.2
  • Improvements:
  • Bug fixes:
May 26, 2026 Link
1.15.1
  • Bug fixes:
March 23, 2026 Link
1.15.0
  • New features:
  • Improvements:
  • Bug fixes:
Form 4BL
The following were recommended updates for Form 4BL printers:
1.17.1
  • New fatures:
  • Improvements:
    • Form Mobile
  • Bug fixes:
1.17.0
  • Improvements:
  • Bug fixes:
1.16.1
  • New features:
  • Improvements:
  • Bug fixes:
June 18, 2026 Link
1.15.2
  • Improvements:
  • Bug fixes:
May 26, 2026 Link
1.15.1
  • Bug fixes:
March 23, 2026 Link
1.15.0
  • New features:
  • Improvements:
  • Bug fixes:
Form 4L
The following were recommended updates for Form 4L printers:
1.17.1
  • New fatures:
  • Improvements:
    • Form Mobile
  • Bug fixes:
1.17.0
  • Improvements:
  • Bug fixes:
1.16.1
  • New features:
  • Improvements:
  • Bug fixes:
June 18, 2026 Link
1.15.2
  • Improvements:
  • Bug fixes:
May 26, 2026 Link
1.15.1
  • Bug fixes:
March 23, 2026 Link
1.15.0
  • New features:
  • Improvements:
  • Bug fixes:
Form 3BL
The following were recommended updates for Form 3BL printers:
2.5.6
  • Compatible with PreForm 3.33.0 and later
  • Bug fixes:
    • Fixed issue where Open Material Mode licenses can disappear from a printer even though the license is active
March 24, 2026 Link
Form 3L
The following were recommended updates for Form 3L printers:
2.5.6
  • Bug fixes:
March 24, 2026 Link
Form Wash L V1 and Form Wash L V2
The following were recommended updates for the Form Wash L:
1.4.0
  • Added support for Resin Washing Solution on Form Wash L. When Resin Washing Solution is selected, the solvent monitor will measure saturation of the solvent.
March 17, 2026 Link
Form Cure L V1
The following were recommended updates for the Form Cure L V1:
1.3.0
  • Added support for Fast Model V1 Resin, Black V5 Resin, Clear V4.1 Resin, Clear V5 Resin, Durable V2.1 Resin, Elastic 50 V2 Resin, Flexible 80 V1.1 Resin, Grey V5 Resin, Rigid 10K V1.1 Resin, Tough 1500 V1.1 Resin, Tough 2000 V1.1 Resin, White V5 Resin, Flame Retardant V1 Resin, and Precision Model V1 Resin
Form 3B/Form 3B+
The following were recommended updates for Form 3B printers:
2.5.6
  • Bug fixes:
March 24, 2026 Link
Form 3/Form 3+
The following were recommended updates for Form 3 printers:
VersionWhat's NewDateDownload
2.5.6
  • Bug fixes:
March 24, 2026Link
The following were recommended updates for Form 3 and Form 3B printers connected to a Form Auto:
2.4.0
March 21, 2024 Link
2.3.0
  • Enabled the printer to start jobs sent using custom print settings from the new Print Settings Editor tool in PreForm
  • Fixed a bug where some tanks programmed to a material not for biocompatible applications could be reprogrammed to a material for biocompatible applications
  • Added the ability to use the new High Volume Resin System on Form 3, Form 3+, Form 3B, and Form 3B+ printers
November 15, 2023 Link
2.2.1
  • Compatible with PreForm 3.29.0 and later
  • Fixed a bug that made Form Auto harvest video not visible in Dashboard
October 17, 2023 Link
2.2.0
  • Automatically sets Z-Height Offset value when a Form Auto is plugged in
September 21, 2023 Link
Form 2
The following were recommended updates for Form 2 printers:
1.19.26
  • Compatible with PreForm 3.24.0 and later
  • Updated the list of certified cartridge production facilities
January 25, 2023 Link
1.19.25
  • Added support for PU Rigid 650 Resin at 50 and 100 microns
  • Added support for PU Rigid 1000 Resin at 50 and 100 microns
May 19, 2022 Link
1.19.24
  • Added support for BioMed Black Resin at 50 and 100 microns
  • Added support for BioMed White Resin at 50 and 100 microns
  • Various bug fixes
April 12, 2022 Link
1.19.23
  • Improved Dental LT Clear Resin cartridge detection
  • Various bug fixes
March 3, 2022 Link
1.19.22
  • Added support for IBT Resin
  • Various bug fixes
February 16, 2021 Link
1.19.21
  • Added support for Castable Wax 40 Resin
  • Various bug fixes
January 7, 2021 Link
1.19.20
  • Added support for Rigid 10K Resin
  • Added support for Draft V2 Resin
  • Various bug fixes
October 27, 2020 Link
Form 1+
The following were recommended updates for Form 1+ printers:
1.40
  • This is the latest version of firmware that is compatible with the Form 1+
  • Dashboard registration from printer
  • Display MAC addresses in the UI
  • Pre-print checks for failed uploads
1.3f
  • Peel cycle optimizations
  • Print speed optimizations
  • Add capability to better handle fine tuning settings
  • Fix occasional incorrect LCD display
May 19, 2014 N/A
Older versions
