Form Cure V2 time and temperature settings
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings.
Select the material type and version to see the recommended Form Cure V2 time and temperature settings. To post-cure previous resin formulations with the Form Cure, use the recommended time and temperature for the closest resin version.
Over-curing is acceptable, unless otherwise stated. Increase the post-curing time for thick, bulky parts because they are slower to heat to the proper temperature.
For parts printed in a Formlabs resin for biocompatible applications, follow the post-curing steps in the relevant instructions for use or application guide. For Formlabs Fast Cure settings, see the support article Fast Cure time settings.
Tip:
Looking for settings for the Form Cure V1? Click here.
Form Cure V2 settings
Resin Post-cure setting Post-cure time Post-cure temperature
Alpha Black Resin
Alpha Clear Resin
Alpha Fast Resin
Alpha Grey Resin
Alpha Model Resin
Alpha White Resin
Default 1 min No heat
Maximum strength 5 min 60 °C
Alumina 4N Resin N/A N/A N/A
BEGO™ VarseoSmileⓇ TriniQⓇ Resin Full post-cure Refer to the Compatibility Overview for washing and post-curing instructions for this resin. View the PDF at the attached link.
BioMed Amber Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Black Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Clear Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Durable Resin V1
BioMed Durable Resin V1.1
BioMed Flex 50A Resin11
(formerly BioMed Elastic 50A Resin)
BioMed Flex 80A Resin11 Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed White Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Black Resin V4/V4.1 Default 10 min 60 °C
Black Resin V5 Default 1 min No heat
Full cure 5 min 60 °C
Castable Wax Resin
Castable Wax 40 Resin
N/A3 N/A N/A
Ceramic Resin N/A¹ N/A N/A
Clear Cast Resin V1 Default 5 min 60 °C
Clear Resin V4 Default 5 min 60 °C
Clear Resin V4.1 Default 7 min 60 °C
Clear Resin V5 Default 1 min No heat
Color Kit Default 10 min 60 °C
Color Resin V5 Default 1 min N/A
Full cure 10 min 60 °C
Custom Tray Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Dental LT Clear Resin V2 Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Dental LT Comfort Resin V1
Dental LT Comfort Resin V1.1
Denture Base Resin V1 Full post-cure² Refer to the Instructions for Use for washing and post-curing instructions for this resin.
Denture Base Resin V2 Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Denture Teeth Resin Full post-cure² Refer to the Instructions for Use for washing and post-curing instructions for this resin.
Draft Resin V2 Better elongation 5 min No heat
Better UTS 5 min 60 °C
Durable Resin V2
Durable Resin V2.1
Full post-cure4 12 min 60 °C
Flexible 50A Resin
(formerly Elastic 50A Resin V2)
Full post-cure5 7 min 70 °C
ESD Resin Default 10 min 70 °C
Fast Model Resin Default 1 min No heat
Flame Retardant Resin Default 5 min preheat
10 min post-cure
100 °C
Flexible 80A Resin V1
Flexible 80A Resin V1.1
Default 3 min 60 °C
Flexible 80A Resin V2 Default Cycle 15: 5 min
Cycle 2: 5 min
Cycle 15: No heat
Cycle 2: 80 °C
Grey Resin V4 Grey Resin V4.1 Default 10 min 60 °C
Grey Resin V5 Default 1 min No heat
Grey Pro Resin Default 8 min 80 °C
High Temp Resin V2 Default 15 min  80 °C
Thermal post-cure 180 min 160 °C
IBT Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
IBT Flex Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Model Resin V2 Default 10 min 60 °C
Model Resin V3 Default 2 min 60 °C
Permanent Crown Resin Full post-cure² Refer to the Instructions for Use [EN] [EU] for washing and post-curing instructions for this resin.
Precision Model Resin Default 1 min No heat
Premium Teeth Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
PU Rigid 650 Resin N/A Refer to the support article Using PU Rigid 650 Resin.
PU Rigid 1000 Resin  N/A Refer to the support article Using PU Rigid 1000 Resin.
Rigid 4000 Resin Default 6 min 80 °C
Rigid 10K Resin V1
Rigid 10K Resin V1.1
Default 3 min preheat
7 min post-cure
80 °C
Silicone 40A Resin Default 10 min 60 °C
Surgical Guide Resin Full post-cure² Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Temporary CB Resin Full post-cure² Refer to the Instructions for Use for washing and post-curing instructions for this resin.
Tough 1000 Resin Default 12 min 70 °C
Low warp 12 min No heat
Tough 1500 Resin V1
Tough 1500 Resin V1.1
Tough 1500 Resin V2
Tough 2000 Resin V1
Tough 2000 Resin V1.1
Low warp 7 min No heat
Default 7 min 70 °C
Tough 2000 Resin V2 Low warp 12 min 40 °C
True Cast Resin V1 Full post-cure 3 min N/A
White Resin V4
White Resin V4.1
White Resin V5 Default 1 min No heat
1: Does not require post-curing. After washing, allow parts to fully dry before firing/casting.
2: This post-cure setting ensures that parts achieve both biocompatibility and optimum mechanical properties. Read the Manufacturing Guide for a full description of the workflow.
3: Does not require post-curing. Allow parts to fully dry before casting.
4: For parts printed with Durable Resin, the tensile modulus increases throughout the first hour of post-curing.
5: Place dry parts in a glass beaker (or other UV-transparent container) and completely submerge the parts in room temperature water.
Downloadable PDF
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings when using a new resin or revised formulation.
