Optical properties of selected Formlabs SLA resins
Below is data about the optical properties of selected Formlabs SLA resins. Use this data along with the information in Choosing the right material and the technical data sheet (TDS) for your selected material to pick a resin and evaluate your printed parts. If data for your material is not available, choose the closest comparable material and interpolate or extrapolate as necessary. For other requests, reach out to Formlabs Support or your sales representative.
Refractive index (RI) and transmission spectra of Clear Resin V4
The transmission spectra and refractive index (RI) of Clear Resin V4 has been thoroughly studied and published. For more information, see Fabrication of optical components using a consumer-grade lithographic printer.
The average refractive index of Clear Resin V4 is approximately 1.51. Below is a summary of the refractive index of Clear Resin V4 at different wavelengths.
Wavelength (nm) Refractive Index (RI)
4861.514
5461.511
5891.508
6561.505
Refractive index (RI) of other resins
Below is a summary of the average refractive indices of a selection of resins, measured across a broad band of wavelengths. Note that part geometry and post-processing may impact refractive index.
ResinRefractive index (RI)
Clear Resin V51.6177
Durable Resin V2.11.5436
Flexible 80A Resin1.687
Elastic 50A Resin V21.4823
High Temp Resin V21.5134
Gloss testing (ASTM D523)
Gloss testing measures the capacity of a surface to reflect light. A higher number indicates a reflective material, whereas a lower number indicates a matte surface. Testing was performed with a measurement angle of 60°. Part geometry and printing orientation may impact the gloss measurements. In general, parts printed in the X/Y direction (i.e., horizontal, laying down) are more glossy than parts printed oriented along the Z-axis (i.e., vertical, standing up).
ResinGloss measurement (X/Y orientation)Gloss measurement (Z orientation)
Clear Resin V58924
Black Resin V5182
Grey Resin V5322
White Resin V5444
Fast Model Resin357
Tough 1500 Resin V2256
Tough 2000 Resin V12216
Durable Resin V2.16528
Rigid 4000 Resin V153
Rigid 10K Resin42
Elastic 50A Resin V25017
High Temp Resin V26846
Flame Retardant Resin11
Resin behavior in microwaves
Formlabs resin is not transparent to microwaves. If printed parts are microwaved, they heat rapidly and may experience thermal degradation. Formlabs does not recommend microwaving any resin-printed parts.
Resin fluorescence
Most Formlabs resins exhibit high fluorescence under UV light, emitting a bluish glow. Black Resin and Dental SG Resin do not fluoresce.
