TIP:
To cancel a print, press and hold the power button for 3 seconds.
As the Form 1+ prints, the resin level drops. Learn how to refill the resin tank mid-print to ensure a successful print.
Refilling mid-print
You can add more resin at any time during the print, but overfilling could result in spillage and damage to your machine. If your model is estimated to use more than 200 mL of resin, you will need to top up the resin tank mid-print.
1. Pause the print
To refill your resin tank during a print, hit the power button one time to pause your print.
2. Pour resin into tank
3. Fill to maximum fill line slowly
4. Close cover and press the button once to resume printing
TIP:
After any print (successful or not), make sure to remove any cured resin from the build platform and the resin tank using the scraper in your Finish Kit.
