Replacing a Form Cure L V1 LED module cooling fan
The Form Cure L V1 has three LED modules that expose printed parts to light during post-curing. Each LED module is cooled by a fan. If any of the LED module cooling fans are malfunctioning or broken, printed parts may not post-cure properly and may not reach their optimal mechanical properties.
Use this guide to remove and replace the Form Cure L V1 LED module cooling fans.
Required supplies:
Required supplies:
Third-party:
  • 2.5 mm hex driver
  • Nitrile gloves
Estimated time: 30 minutes (additional time may be required to allow the post-cure chamber to cool if the machine was recently in use)
Danger:
Preparing the workspace
Overview: Prepare the Form Cure L and a dust-free workspace for replacing the LED module cooling fan.
Step 1: Unplug the networking cables and Wi-Fi antenna
Disconnect the Ethernet and USB cables from the unit, if they are connected. Unscrew and remove the Wi-Fi antenna.
Step 2: Unplug the machine
Disconnect the power cable before continuing with maintenance. Do not perform maintenance on the machine while it is connected to power. Wait five minutes after disconnecting the machine from power before proceeding. If the machine was recently in use, the post-cure chamber will be warm. Wait at least two hours for the chamber to cool.
Danger:
Performing maintenance on the machine while it is plugged in increases the risk of electric shock. Never remove the panels of the machine while it is plugged in. Never reconnect the machine to power while the panels are uninstalled.
Removing the top shell (top and left LED module cooling fans)
Overview: If you are replacing the cooling fan for the top or left LED module, unscrew and remove the top shell.
The Form Cure L contains sensitive electronic components. Ground yourself before touching any electronics in the machine by using a grounding strap or touching a grounded piece of metal.
Step 1: Unscrew the top shell retention screws
The top shell is secured to the frame of the machine with six hex screws. When facing the front of the Form Cure L, two screws are located on the right side and four are located on the left. Use a 2.5 mm hex driver to unscrew and remove the screws.
Step 2: Remove the top shell
Slide the top shell towards the back of the machine to unhook it from the frame. Lift the top shell away from the machine and set it to the side.
Removing the bottom shell (bottom LED module cooling fan)
Overview: If you are replacing the cooling fan for the bottom LED module, unscrew and remove the bottom shell.
Step 1: Remove the turntable
Open the Form Cure L door. Lift the turntable out of the machine and set it aside. Close the Form Cure L door. The Form Cure L turntable is made of glass; handle with care.
Step 2: Unscrew the bottom shell retention screws
The bottom shell is secured to the frame of the machine with 15 hex screws. When facing the front of the Form Cure L, two screws are located on the right side, two screws are located on the left side, and 11 screws are located on the bottom.
Carefully tilt the machine away from you and place it on its back. Use a 2.5 mm hex driver to unscrew and remove the screws.
Step 3: Remove the bottom shell
Lift the bottom shell away from the machine and set it to the side.
Removing the LED module cooling fan
Overview: Unscrew, unplug, and uninstall the LED module cooling fan that is being replaced.
Step 1: Locate the LED module cooling fan
Step 1: Locate the led module cooling fan
The LED module cooling fan is a round blower fan, positioned at one end of the corresponding LED module. Locate the LED module cooling fan you are replacing.
Step 2: Remove the LED module cooling fan retention screws
The top and bottom LED module cooling fans are each secured by two screws. The left fan is secured by a single screw. For the cooling fan you are replacing, use a 2.5 mm hex driver to loosen and remove the screw or screws.
Step 2: Remove the led module cooling fan retention screws
Step 3: Disconnect the fan cable
Follow the wires from the LED module cooling fan and locate the fan cable plug. The top and bottom LED module cooling fan wiring is routed through a cable management channel. You may need to slide the wires out of the channel to access the plug.
Press the latch on the fan cable plug, grip the connectors, and separate them from one another. Do not pull on the wires themselves.
Step 4: Remove the LED module cooling fan
Note the orientation of the cooling fan for future reference. Lift the fan out of the Form Cure L and set it aside.
Step 5: Remove additional LED module cooling fans (optional)
If you are replacing more than one LED module cooling fan, repeat steps 1–4.
Step 4: Remove the led module cooling fan
Installing the new LED module cooling fan
Overview: Mount and secure the new cooling fan.
Step 1: Mount and secure the replacement cooling fan
Position the replacement cooling fan on its mounting surface, aligning the screw holes in the fan with the posts on the machine’s frame. Lower the cooling fan into place, ensuring that the label on the fan faces the machine’s frame, the screw holes in the fan sit over the posts, and the fan outlet aligns with the opening in the LED module.
Reinstall the retention screw or screws and tighten with a 2.5 mm hex driver until finger tight.
Step 2: Reconnect the fan cable
Reconnect the fan cable. The connectors will only plug into each other properly in the correct orientation. Be careful not to bend the pins in the connectors.
Step 3: Install additional LED module cooling fans (optional)
If you are replacing more than one LED module cooling fan, repeat steps 1–2.
Reinstalling the top shell (top and left LED module cooling fans)
Overview: If you replaced the cooling fan for the top or left LED module, reinstall and secure the top shell after performing any other maintenance procedures.
Step 1: Reinstall the top shell
Lower the top shell onto the Form Cure L. Make sure you do not pinch any wires between the shell and the frame of the machine. Slide the top shell towards the front of the machine to hook it into place. Check that the screw holes in the top shell line up with the corresponding screw holes in the frame of the machine.
Step 2: Secure the top shell
Thread one 2.5 mm hex screw into each of the six screw holes in the top shell. Using a 2.5 mm hex driver, tighten the screws until finger tight.
Reinstalling the bottom shell (bottom LED module cooling fan)
Overview: If you replaced the cooling fan for the bottom LED module, reinstall and secure the bottom shell after performing any other maintenance procedures.
Step 1: Reinstall the bottom shell
Lower the bottom shell onto the Form Cure L. Make sure you do not pinch any wires between the shell and the frame of the machine. Check that the screw holes in the bottom shell line up with the corresponding screw holes in the frame of the machine.
Step 2: Secure the bottom shell
Thread one 2.5 mm flat head hex screw into each of the screw holes in the left and right side of the bottom shell. Thread one 2.5 mm button head hex screw into each of the screw holes in the bottom of the machine. Using a 2.5 mm hex driver, tighten the screws until finger tight.
Step 3: Reinstall the turntable
Open the Form Cure L door. Place the turntable onto its mount. Close the Form Cure L door. The Form Cure L turntable is made of glass; handle with care.
Finalizing the repair
Overview: After reinstalling the shell, power on the machine and perform final checks.
Step 1: Power on the machine
Connect the power cable to the Form Cure L and the power supply. Flip the breaker switch on the back of the unit to the ON position to turn on the machine.
Step 2: Test the repair
Start a post-cure cycle to test the replacement LED module cooling fan. Monitor the Form Cure L to ensure that the post-cure cycle runs normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
