Replacing the Fuse 1 generation hopper LED board
On Fuse 1 generation printers, the powder hopper is lit by a set of LEDs at the top of the hopper. A faulty or malfunctioning LED board may make it harder to judge the amount of powder in the hopper.
Use this guide to replace the hopper LED board on a Fuse 1 generation printer.
Fuse 1 display
Required supplies:
  • Replacement hopper LED board
Third-party:
  • 2.0 mm hex driver (flat-end)
  • 5.5 mm socket driver
  • Flat-end screwdriver
Estimated time: 45–60 minutes, plus time to empty the powder hopper if needed
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the hopper LED board.
Step 1: Prepare the workspace
Step 2: Empty the hopper
Insert an empty build chamber. Tap Settings > Calibration > Empty Hopper on the printer’s touchscreen. Follow the on-screen prompt on the Empty Hopper screen to transfer the powder from the hopper to the build chamber. This process may take up to an hour.
Step 3: Clean the hopper
Vacuum the remaining powder out of the hopper. Lay a paper towel at the bottom of the hopper to catch any falling parts.
Step 4: Unplug the printer
Danger:
Removing the top panel
Overview: Remove the top panel to access the interior of the printer.
Step 1: Remove the top panel screws
Using a 2.5 mm hex driver, remove the 26 6 mm M4 countersunk screws securing the top panel to the printer:
Remove the top enclosure panel
  • Six 6 mm screws on the front end of the buffer-side
  • 12 6 mm screws on top of the printer
  • Eight 6 mm screws on the hopper-side
Set the screws aside.
Step 2: Remove the top panel
Lift the top panel off of the printer by grabbing the IR sensor door and the rear-most edge. Set the top panel aside.
Removing the hopper-side panel and hopper shell
Overview: Remove paneling on the hopper side of the printer to access the LED board.
Step 1: Begin removing the hopper-side panel screws
Using a 2.5 mm hex driver, loosen and remove the two black (circled in red) and one chrome (circled in blue) 8.0 mm M4 button head screws from the back-left of the printer. Take note of the locations of these screws, as the placement of the chrome screws is critical to the printer's electrical grounding. Set the screws aside.
Remove the top & hopper-side panels
Step 2: Continue removing the hopper-side panel screws
Move to the hopper side of the printer. Using a 2.5 mm hex driver, loosen and remove the 10 M4 countersunk screws holding the hopper-side panel to the printer. Remove the top-most 6.0 mm countersunk screws last to make removing the panel easier. Set the screws aside.
  • Three 16.0 mm screws, circled in green
  • Three 12.0 mm screws, circled in blue
  • Four 6.0 mm screws, circled in red
Step 3: Tilt the hopper-side panel
Allow the panel to tilt away from the printer, allowing access to the interlock switch cables. Do not remove the panel at this time.
Step 4: Disconnect the interlock switch and remove the hopper-side panel
Locate the black and red cables leading to the interlock switch on the inner left-hand side of the panel. The cables are retained by a cable clamp. Unlock the cable clamp and disconnect the cable labeled C033.
Separate the hopper-side panel from the printer, taking care to ensure that none of the cables are caught or tangled. Set the panel down on a flat, clean surface.
Step 5: Remove the inner door handle
Using a 2.0 mm hex driver, loosen and remove the four 10.0 mm M3 black countersunk screws holding the inner door handle to the printer. Remove the door handle and set it and the screws aside.
Step 6: Remove the hopper shell
Grip the sides of the hopper shell. Carefully lift the shell upwards then pull it away from the printer. Set the hopper shell and lid aside.
Removing the original hopper LED board
Overview: Disconnect and remove the original hopper LED board
Step 1: Disconnect the hopper LED board cable
Locate the LED board, positioned at the front of the hopper along its top edge. Disconnect the JST connector labeled C048 from the board.
Replace the Hopper LED Board
Step 2: Remove the LED board mounting screws
The hopper LED board is secured using two screws, each with a corresponding nut on the inside of the hopper lip. Use a 5.5 mm socket to hold one of the nuts in place, then unscrew the corresponding screw with a flat-end screwdrive. Take care not to let the nut fall into the hopper. Repeat with the other screw and nut, then set the screws and nuts aside.
Step 3: Remove the hopper LED board light diffuser
Remove the hopper LED board diffuser from under the hopper lip. Be careful not to drop the part into the hopper.
Step 4: Remove the hopper LED board
Carefully peel off the protective foam seal holding the LED board to the edge of the hopper. Set the foam aside for reuse. Remove the hopper LED board and set it aside for disposal with electronic waste.
Installing the replacement hopper LED board
Overview: Mount, secure, and connect the replacement hopper LED board.
Step 1: Mount the new hopper LED board
Place the new hopper LED board on its mounting surface with the cable connector oriented to the left. Reapply the protective foam seal across the top edge of the board.
Step 2: Secure the LED board and diffuser
Hold the diffuser in place under the hopper lip, opposite the LED board. Insert a 2.5 mm hex screw into one of the screw holes and secure it with a nut. Repeat with the other screw and nut.
Step 3: Reconnect the hopper LED board cable
Connect the cable labeled C048 to the hopper LED board.
Reinstalling the hopper shell and hopper-side panel
Overview: After installing the new hopper LED board, reinstall the paneling on the hopper side of the printer.
Step 1: Mount and secure the inner door handle
Align the four screw holes in the inner door handle with the corresponding screw holes on the front edge of the hopper side of the printer. Thread one 10.0 mm M3 black countersunk screw into each of the four screw holes, then use a 2.0 mm hex driver to tighten until snug.
Replace the top & hopper-side panels
Step 2: Mount the hopper shell
Grab the sides of the hopper shell and bring it towards the printer. Align the shell with the hopper body, then slide it down on top of the hopper.
Step 3: Reconnect the interlock switch cable
Align the bottom of the hopper-side panel to the bottom of the printer and allow it to lean against you. Reconnect the interlock switch cable, labeled C033, to its receptacle. Route the cables into the cable clamp with the connector positioned below the clamp. If necessary, tuck the interlock cable slack into the side of the printer’s frame.
Step 4: Begin securing the hopper-side panel
Thread one M4 countersunk screw into each of the 10 screw holes in the hopper-side panel. Using a 2.5 mm hex driver, tighten until snug. For greatest convenience and ease of installation, thread and tighten in the following order:
  1. Four 6.0 mm screws below the hopper, circled in red
  2. Three 16.0 mm screws below the filter door, circled in green
  3. Three 12.0 mm screws above the filter door, circled in blue
Step 5: Continue securing the hopper-side panel
Thread the two black 8.0 mm M4 button head screws into the screw holes circled in red in the image here. Thread the chrome 8.0 mm M4 button head screw into the screw hole circle in blue here. Using a 2.5 mm hex driver, tighten until snug.
Reinstalling the top panel
Overview: After installing the new hopper LED board, reinstall and secure the top panel.
Step 1: Align the top panel
Lift the top panel and place it on top of the printer. Align the screw holes in the top panel with the corresponding holes in the printer frame.
Step 2: Secure the top panel screws
Thread a 6 mm M4 countersunk screw into each of the 18 marked screw holes in the top panel:
Using a 2.5 mm hex driver, tighten the screws until snug.
Finalizing the repair
Overview: After installing the replacement hopper LED board, power on the printer and perform final checks.
Step 1: Power on the printer
Connect the power cable to the printer and the power supply. The printer initializes. Check that the hopper LEDs light up. Contact Formlabs Support or your certified service provider to share the results of the procedure.
