Ensure the internet or intranet connection you wish to connect the printer to is properly configured to be offline. A misconfigured internet connection may allow the printer to connect to the Formlabs network and share data.
Customers that require their work to be conducted in privacy may wish to configure a manual IP pointing to an offline network to maximize their security. This allows the printer to communicate with the computer via an offline Local Area Network (LAN) connection, without requiring the computer to communicate with the internet via a standard internet connection.
An offline LAN connection is most suited for the following environments:
Note:
The printer cannot contact the outside internet with this setup.
Opting out of data collection within PreForm
If a computer has an outside internet connection, PreForm automatically communicates with Formlabs to send telemetry data about prints and printers if you do not choose to opt out.
Note:
For full details on information collected by Formlabs please consult Formlabs Privacy Policy, or email questions to [email protected].
Setting up an offline LAN for a single printer
A single printer is capable of communicating directly with a single computer via an Ethernet cable. All Formlabs printers support auto-MDIX.
Note:
The specifics given in this procedure have been provided as an example—your own TCP and other settings may be different.
To set up an offline LAN connection:
### must be unique on this LAN network.
Setting up an offline LAN for multiple printers
Connect your computer to multiple printers by utilizing an Ethernet switch. This switch is needed if you want to have one computer send print jobs to multiple printers via an offline network.
Note:
To set up an offline LAN connection using an Ethernet switch:
