Standard resin tanks and Resin Tanks LT (Form 2)
All Form 2 resin tanks are comprised of a tank frame, a clear acrylic tank window, and an elastic layer on top of the acrylic window inside the tank. For a detailed look at resin tanks and their components, read the support article 3D glossary (Form 2).
alt text
Each resin tank includes a wiper, which slides across the bottom of the tank between print layers to mix the resin, clear debris from the optical path, and prevent pigment from settling into the elastic layer.
alt text
alt text
The following Formlabs materials wear down standard resin tanks more quickly than standard resins:
  • Castable Resin
  • Dental SG Resin
  • Denture Teeth Resin
  • Denture Base Resin
  • High Temp Resin
  • Model Resin
For information about which resin tanks are required or recommended for each resin, read the support article Choosing the right material.
Next: Storing standard resin tanks and Resin Tanks LT (Form 2)
