Turntable does not spin (Form Cure L)
Explanation
The Form Cure L uses a turntable to ensure balanced post-curing across all exposed surfaces. Under normal operation, the turntable spins during post-curing cycles. If your Form Cure L’s turntable is not spinning during post-curing cycles, turntable spinning may be disabled on the Form Cure L’s UI, or there could be an issue with the turntable’s gear or motor.
Causes
  • Turntable spinning is disabled
  • Gear on the underside of the turntable is misshapen
  • Motor issues
Symptoms
  • Turntable does not spin when post-curing cycle starts
Troubleshooting steps
  1. Confirm that turntable spinning is enabled.
Form Cure L V1Form Cure L V2
  1. On the Home screen, tap the wrench icon to access the Settings menu. The Settings menu appears.
  2. Tap System. The System menu appears.
  3. Make sure that Turn Table Spinning is toggled ON. The toggle turns blue when turntable spinning is enabled. If Turn Table Spinning is disabled, click the toggle to activate the feature.
  1. On the Home screen, tap the gear icon to access the Settings menu. The Settings menu appears.
  2. Make sure that Turntable rotation is toggled ON. The toggle turns blue when turntable spinning is enabled. If Turntable rotation is disabled, click the toggle to activate the feature.
  1. Check the coupler on the underside of the turntable.
Form Cure L V1 Form Cure L V2
  1. Check that the coupler on the underside of the turntable is present and undamaged.
  2. Check to see if the turntable is able to fit into the Form Cure L. The turntable should fit without any clearance issues and slides onto the peg on the Form Cure L.
    1. If the turntable does not fit on the peg, contact Formlabs Support.
  2. Check that the corresponding coupler in the Form Cure L is present and undamaged. Impacts from heavy parts dropped onto the turntable, such as large parts printed in Rigid 10K Resin, can crack the coupler.
    1. If the coupler is cracked, you can print a replacement. Formlabs recommends a tough and impact-resistant resin, such as Tough 2000 Resin V2. The coupler mounts on the motor shaft via a press-fit.
  1. If the turntable has issues spinning, take a video of spinning the turntable by hand and a photo of the gear on its underside. Send the video and photo to Formlabs Support.
