Cleaning the Fuse 1 generation recoater roller
The recoater distributes powder in an even layer as it moves across the print bed. Clean the recoater roller after 100 hours of printing to prevent divots and drag marks at the top surface of parts.
Depending on the date of manufacture of your printer and any retrofits you have performed, your machine may have one of two recoater rollers:
  • Fuse 1 Generation Recoater Roller V1 (RP-FS1-RU-01)
    • Smooth
    • Installed on Fuse 1 generation printers manufactured before November 2026
  • Fuse 1 Generation Recoater Roller V2 (RP-FS1-RU-02)
The recommended cleaning process is the same for both types of roller.
Note: The cleaning procedure detailed in this video is only applicable to the Fuse 1 Generation Recoater Roller V1. For a procedure that can be applied to either roller version, see the steps below.
Caution:
Do not use compressed air or an air gun to clean the print enclosure, build chamber, or any other component. Mobilizing loose powder increases the risk of unintentional inhalation or ingestion.
Required supplies
Estimated time required: 5–20 minutes
Supplies:
  • Particulate filtering respiratory protection (N95 or better)
  • Non-reactive nitrile gloves
  • Safety glasses
  • Non-abrasive microfiber cleaning cloths
  • Non-abrasive cleaning sponge
  • Ethanol (optional)
  • Alconox (optional)
Cleaning the recoater roller
Remove the build chamber and move the roller to the middle of the printer. For light buildup, scrub the surface of the roller with a sponge, then clean with ethanol. For a deeper clean, soak the roller.
Fuse 1 recoater roller cleanliness
The recoater does not need to be manually homed after cleaning. It will automatically home during pre-print.
Note:
If there are deep scratches or burrs on the recoater roller, replace the roller. Replacement recoater rollers are available for purchase on the Formlabs Store:
Step 1: Remove the build chamber
It is easier to clean the full surface of the roller when there is no build chamber in the printer.
Step 2: Move the recoater to the middle of the printer
Use Motor Moves to move the recoater to the middle for easier access to the roller surface.
  1. On the touchscreen, navigate to Maintenance > Motor moves
  2. Touch and hold the appropriate directional toggle that will move the recoater out into the middle of the printer.
The Fuse 1 generation recoater moved to the center of the build chamber
Step 3: Wipe the recoater roller
Using a dry microfiber cleaning cloth, wipe the full surface of the roller. If there is any hardened debris remaining on the surface:
  1. Wet a soft sponge with Alconox and water. Do not use an abrasive sponge or the coarse side of a dual-texture sponge, as this can damage the recoater roller.
  2. Lightly scrub the surface of the roller until it looks visually clean.
  3. Wipe the roller with a clean microfiber cloth wetted with water.
  4. Wipe the roller with a clean microfiber cloth wetted with ethanol.
  5. Ensure that the roller is fully dry after it is clean.
Step 4 (optional): Soak the recoater roller
If there is still significant buildup, remove it from the printer and soak it before wiping:
  1. Uninstall the recoater roller following the steps in the guide for replacing the Fuse 1 generation recoater roller.
  2. Soak the recoater roller in Alconox for several minutes.
  3. Lightly scrub the roller with a sponge soaked in Alconox and water. Do not use an abrasive sponge or the coarse side of a dual-texture sponge, as this can damage the recoater roller.  Repeat the soak if necessary.
  4. Wipe the roller with a clean microfiber cloth wetted with water.
  5. Wipe the roller with a clean microfiber cloth wetted with ethanol.
  6. Ensure that the roller is fully dry after it is clean.
  7. Reinstall the recoater roller, again following the steps in the guide for replacing the Fuse 1 generation recoater roller.
