List of unavailable replacement parts
Replacement parts for end-of-life products are available as supplies last. This is a list of replacement parts that have stocked out and will not be reordered. If you are troubleshooting your device and reach a step that would require a part that is no longer available, contact Formlabs Support or your authorized reseller.
SLA printers
Form 3L generation
SKU Product AMER EMEA APAC
RP-F3A-CDA-01 Form 3 and Form 3L Cartridge Dispense Arm     X
F3-CSF-01 Form 3 and Form 3L Cartridge Spring Fingers Replacement Kit   X
RP-QRBPL-PSF-01 Form 3L Build Platform 2L Print Surface Assembly     X
RP-F3L-DP-01 Form 3L Display Assembly     X
RP-F3L-FCF-01 Form 3L Full Cartridge Floor X X X
RP-F3L-ISE-01 Form 3L Inductive Sensor     X
RP-F3L-LVL-01 Form 3L LevelSense Board     X
F3L-LPU-01 Form 3L Light Processing Unit   X
RP-F3L-MIX-01 Form 3L Mixer Assembly X   X
RP-F3L-MXC-01 Form 3L Mixer Coupler Assembly     X
RP-F3L-RFAN-01 Form 3L Rear Fan     X
RP-F3L-RHTR-01 Form 3L Rear Heater     X
F3L-PKG-REPL Form 3L Replacement Packaging X   X
RP-F3L-RFID-01 Form 3L RFID Reader     X
F3L-FR-01 Form 3L Roller Holder (Optical Window Assembly)   X X
RP-F3L-SHFX-01 Form 3L Short Flex Cable     X
RP-F3L-WIFI-01 Form 3L Wi-Fi Antenna X X X
Form 3 generation
F3-ASM-000117 Form 3 and Form 3B Cover     X
RP-BP-F3-PS-01 Form 3 Build Platform 2 Replacement Print Surface   X X
RP-F3-FCF-01 Form 3 Cartridge Floor Assembly   X
F3-CSF-01 Form 3 Cartridge Spring Fingers     X
RP-F3-CB-01 Form 3 Cover Bracket     X
RP-F3-HING-01 Form 3 Cover Hinge Replacement Kit   X
F3-FD-01 Form 3 Display Assembly   X
RP-F3-FCF-01 Form 3 Full Cartridge Floor Asm X   X
RP-F3-LVS-01 Form 3 LevelSense Board     X
RP-F3-LS-01 Form 3 Limit Switch     X
F3-PKG-REPL Form 3 Replacement Packaging X X X
F3-XLATCH-01 Form 3 X-stage Latch Replacement     X
RP-F3P-HR-01 Form 3+/3B+ Heater     X
RP-F3B-DISP-01 Form 3B Display Assembly X X X
F3B-PKG-REPL Form 3B Replacement Packaging     X
Form 2
F2-HDW-000119 Form 2 Anti Backlash Nut     X
F2-ASM-000083 Form 2 Cartridge Floor Assembly with Drip Catcher     X
F2-ASM-000026 Form 2 Cover     X
F2-LT-01 Form 2 Level Tool Packet     X
F2-ASM-000011 Form 2 Optical Window Assembly     X
F2-PKG-REPL Form 2 Replacement Packaging     X
F2-IM-000022 Form 2 Rinse Lid     X
F2-CBL-USB Form 2 USB Cable     X
SLA post-processing and accessories
Form Cure V1
FH-CU-PKG-REPL Form Cure V1 Packaging     X
FH-PASM-000008 Form Cure V1 Power Supply   X X
RP-CU-TURN-01 Form Cure V1 Turntable Assembly X   X
Form Wash V1
FH-ASM-000053 Form Wash V1 Bucket X
RP-FW-IMP-01 Form Wash V1 Impeller X   X
Fast Cure
RP-FCU-CTRL-01 Fast Cure Control Board X   X
RP-FCU-LCD-01 Fast Cure Display   X X
RP-FCU-LFLED-01 Fast Cure Left LED Module     X
RP-FCU-MEM-01 Fast Cure Memory Card X X X
RP-FCU-PSU-01 Fast Cure Power Supply   X X
RP-FCU-RTLED-01 Fast Cure Right LED Module     X
RP-FCU-TURN-01 Fast Cure Turntable Tray   X X
RP-FCU-UPLED-01 Fast Cure Upper LED Module     X
RP-FA-LINE-01 Form Auto Cover Actuator     X
RP-FA-QRPN-01 Form Auto Cover Actuator Pin X
RP-FA-ETH-01 Form Auto Ethernet Port   X X
RP-FA-SLID-01 Form Auto Gantry Drawer Slide   X X
RP-FA-DSHF-01 Form Auto Gantry Drive Assembly     X
RP-FA-BUCK-01 Form Auto Part Release Bin X X
RP-FA-TRIP-01 Form Auto Part Removal Enclosure (Center)   X X
RP-FA-CATFR-01 Form Auto Part Removal Enclosure (Left)   X X
RP-FA-CATR-01 Form Auto Part Removal Enclosure (Right)   X X
RP-FA-THD-01 Form Auto Print Removal Mechanism     X
RP-FA-COVB-01 Form Auto Printer Cover Adapter     X
SLS printers
Fuse 1+ 30W
RP-FS1-IR-011 Fuse 1 Generation IR Sensor V1 X X X
RP-FS1-PORO-120V2 Fuse 1 Generation heater control board (Post Rock board) 120 V   X
RP-FS1-PORO-230V2 Fuse 1 Generation heater control board (Post Rock board) 230 V X X X
1  Replaced with RP-FS1-IR-02. The original SKU is no longer relevant.
2  Replaced with dual-voltage RP-FS1-PORO-02.
Fuse 1
