Using Rigid 10K Resin
Aviso:
Rigid 10K Resin offers high stiffness, strength, and resistance to heat and chemicals, making it a game-changing industrial material for the most demanding jobs. With a stiffness simulating that of glass and fiber-filled thermoplastics, Rigid 10K Resin is designed to maintain structural integrity under any condition.
rigid-10k-resin
Rigid 10K Resin was developed to have high stiffness, high strength, and high temperature resistance for use in engineering, aerospace, and manufacturing applications.
Recommended for:
  • Strong and stiff functional prototypes
  • Temperature and chemical resistant prototypes
  • High temperature injection molding masters
  • Stiff and strong aerodynamic test models
  • Air and fluid flow components
No se recomienda para:
  • Aplicaciones de alto impacto
Note:
To learn more about the performance or specific material properties of Rigid 10K Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Comparación con otros materiales
 Rigid 4000 Resin,
post-cured
(80 °C)
Rigid 10K Resin,
post-cured
(70 °C)
Rigid 10K Resin,
optional thermal post-cure
(90 °C)
Ultimate tensile strength (MPa)756558
Tensile modulus (GPa)41010
Elongation at break (%)611
Flexural modulus (GPa)3.79.010.0
Izod Impact strength (J/m)191618
Heat deflection temperature (HDT) @ 1.8 MPa (°C)7482110
Heat deflection temperature (HDT) @ 0.45 MPa (°C)88163218
Para saber más sobre las propiedades de las resinas de Formlabs, consulta el directorio de archivos de propiedades de materiales.
rigid-10k-resin
Printing with Rigid 10K Resin
  • Rigid 10K Resin prints at 50 and 100 microns.
  • Use Resin Tank LT (Form 2) or Resin Tank V.2 (Form 3) are required for printing with Rigid 10K Resin. Standard resin tanks are incompatible with Rigid 10K Resin because the elastic layer in a standard resin tank swells when exposed to the uncured material.
  • The extended lifetime of Resin Tank LT does not apply when used with Rigid 10K Resin, a high-performance material that can accelerate wear on the tank. When used with Rigid 10K Resin, Resin Tank LT lasts between 1–2 liters before the elastic layer swells and begins to show wear. Learn how to recognize wear on Resin Tank LT and prolong tank lifetime when printing with Rigid 10K Resin.
  • Before printing, ensure Rigid 10K Resin is mixed thoroughly for best results. Shake the resin cartridge and mix the dispensed resin in the tank with the wiper or a spatula with rounded corners. Mix new resin cartridges and any Rigid 10K Resin stored in the cartridge or tank after several weeks.
  • If the mixer in the resin tank comes uncoupled during printing, try using a mixer from another tank.
  • Parts printed with Rigid 10K Resin offer similar accuracy and strong dimensional stability when compared to parts printed with standard resins.
  • Rigid 10K Resin allows for geometries that are slightly thinner than those possible with standard resins.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Refer to the support article Starting a print to open the model in PreForm, orient it, generate supports, and select print settings.
Acabado
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
After post-curing, the surface of a part printed in Rigid 10K Resin may feel powdery. Rubbing mineral oil or water into the part surface and wiping away any excess will lead to a smoother, less powdery finish.
Requisitos de poscurado
Rigid 10K Resin requires post-curing to reach its optimal mechanical properties and high heat deflection temperature (HDT).
There are two post-curing options for Rigid 10K Resin. Refer to the technical data sheet to understand how different options affect mechanical properties, and choose the post-cure option that is best suited to the intended application.
Refer to the Form Cure time and temperature settings for post-curing requirements.
Media blasting
Formlabs recommends media blasting Rigid 10K Resin printed parts for improved mechanical properties, including tensile, flexural, and impact strength. Media blasting parts reduces surface defects that may cause part failures.
The process of media blasting changes the surface color of Rigid 10K Resin parts from white to cream but does not significantly affect part dimensions.
Comparison with untreated Rigid 10K Resin parts
Rigid 10K Resin parts with and without media blasting were sent for APM testing to compare mechanical and material properties. All parts were media blasted with 70-140 mesh glass beads on all surfaces. See the table below:
Rigid 10K Resin + UV cureRigid 10K Resin + UV cure + thermal cureRigid 10K Resin + UV cure + media blasting% change from media blasting
Tensile Modulus (GPa)101011+ 10%
Ultimate Tensile Strength (MPa)655388+ 35%
Elongation at Break (%)111.7+ 70%
Flexural Modulus (GPa)9109.93+ 10%
Flexural Strength (MPa)126103158+ 25%
Notched Impact Strength (J/m)161820+ 25%
Unnotched Impact Strength (J/m)4741130+ 190%
