Aviso:
Aviso:
Using Flexible 80A Resin and color pigments as part of a digital implant prosthetic workflow, healthcare professionals can now 3D print soft tissue parts that better simulate the gingiva for dental implant modeling purposes. Customizable color pigments allow you to tailor the color and opacity of your final printed model.
Soft Tissue Resin prints at 50 microns and 100 microns.
Note:
To learn more about the performance or specific material properties of Soft Tissue Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Materiales necesarios
Resumen del proceso de trabajo
This is an abbreviated version of the application guide, 3D Printing Soft Tissue for Gingiva Mask on Dental Models [en]. Read the application guide for detailed instructions about the workflow for Soft Tissue Resin.
Escaneo
In order to 3D print a permanent crown or other restoration, use a scanner to collect anatomical data of the patient's dentition. Either scan the patient directly with an intraoral scanner, or use a desktop optical scanner to scan a polyvinyl siloxane (PVS) impression or stone model.
Diseño
Use a dental CAD software package to process and design the restoration before printing. Choose software that offers open STL file export.
Impresión
Aviso:
Follow the instructions in the application guide, 3D Printing Soft Tissue for Gingiva Mask on Dental Models [en], to mix the appropriate shade of Soft Tissue Resin.
Use the PreForm settings for Flexible 80A Resin: 50 microns and 100 microns.
Acabado
La Form Wash agita el baño de disolvente y saca las piezas pasado un tiempo determinado. Lava las piezas según lo descrito en el artículo de asistencia Ajustes de tiempo de la Form Wash. Presta especial atención a la información que afecta a las propiedades mecánicas o a los requisitos de biocompatibilidad.
Si el modelo es hueco o tiene canales internos, asegúrate de que la resina líquida salga de todas las cavidades. Deja que las piezas se sequen por completo antes de llevar a cabo el poscurado.
Requisitos de poscurado
Soft Tissue Resin requires post-curing to reach its optimal mechanical properties.
Refer to the support article Form Cure time and temperature settings for post-curing recommendations.
Recursos adicionales
