Guide to EOAT: Revolutionizing End-of-Arm-Tooling With 3D Printing
SLS 3D printed end of arm tooling EOAT component on a robot, SLS 3D printed gripper
End-of-arm-tooling, or EOAT, refers to the component of a robotic system that interacts directly with the products the system is designed to move, alter, grab, or otherwise affect. EOAT is typically located at the end of a robotic arm, and typical functions include pick-and-place operations, welding, holding devices, and force sensors, among others.
As automation equipment has become nearly ubiquitous within large manufacturing operations, the need for high-quality, custom-designed EOAT has grown as well. EOAT often acts as the customized intermediary between a mass-produced robotic system and a manufacturer’s unique product or workflow.
This customization component makes 3D printing ideal for creating end-of-arm-tooling. Specifically, the material versatility of stereolithography (SLA) 3D printing and the durability and strength of selective laser sintering (SLS) 3D printing lend themselves well to creating end-use EOAT for use in industrial manufacturing scenarios.
Types and Applications of EOAT
in-mold labeling (IML) decorating end of arm tool
In-mold labeling (IML) decorating end-of-arm-tool (EOAT). Photo courtesy of Robotic Automation Solutions.
Vacuum Placement end-of-arm-tool for picking up and moving small caps without the use of suction cups.
Vacuum placement end-of-arm-tool for picking up and moving small caps without the use of suction cups. Photo courtesy of Robotic Automation Solutions.
EOAT is often divided into three main categories: automation, process, and inspection or verification. Strong, durable EOAT in each of these categories can be a main driver of efficiency, productivity, and profitability for manufacturers.
Automation EOATProcess EOATInspection and Verification EOAT
‘Pick-and-place’
Grippers
Magnets
Vacuum/Suction
Welding (torch end)
Cutting (blade end)
Cleaning (pressurized air, etc)
Painting or coating (nozzles and sprayers)
Vision
Radiation
Temperature
Pressure
The specific design and complexity of EOAT depends on the application it’s required to perform, the type of robot to which it’s attached, and the shape, weight, volume, and quantity of the items on which it’s performing the action.
For instance, a pick-and-place robot that moves a package from the end of a conveyor belt into a forklift bucket might use strong retractable ‘claw’ type EOAT if the package is heavy and rigid.  For a small, lightweight package inside a padded envelope, the same pick-and-place robot might use end-of-arm-tooling with suction cups and pressurized air to lightly pick up the envelope and then drop it in the bucket.
vacuum cup system EOAT end of arm tool
Vacuum cup systems end-of-arm-tooling made for picking up a 20-pound, 96-gallon waste container using four suction cups. Photo courtesy of Robotic Automation Solutions.
Vacuum Cup Systems end-of-arm-tooling
Vacuum cup systems end-of-arm-tooling made with 40 customized suction cups mounted to level compensators. Photo courtesy of Robotic Automation Solutions.
Though there are many different possible types of end-of-arm-tooling, the characteristics necessary for good performance are typically the same — highly accurate measurements that can hold tolerances and integrate successfully into the robotic system, light weight so that the robotic system does not have to allocate too much power and force to the tooling rather than the object, and strength, so that repeated actions does not wear on the tooling and cause breakage.
Robotic systems need power, and sometimes the EOAT needs its own power source, so that it can move independently of the larger robotic system. This can be done electrically or pneumatically, hydraulically, or through a combination of those methods. Electrically powered EOAT is typically used for lighter, more delicate operations, while hydraulic or pneumatic-powered EOAT is used in heavier industrial applications such as the automation industry.
Welding in action
Webinar
Quick Custom Welding Fixtures With 3D Printing
Discover how to streamline your tooling process to accelerate rapid prototyping and low-volume production of metal parts with quick and modulable welding fixtures. Our R&D machine shop coordinator shares methods and best practices for 3D printing welding fixtures, including design guidelines, tool temperature study, practical examples, and cost analysis.
Watch the Webinar Now
EOAT Design: How to Design Faster with 3D Printing
a welding robot at Brose
Choosing the right printer and material depends on application, environment, desired result, and many other factors. This welding robot used by Brose has a custom EOAT welding torch tip on it, made of metal, but surrounding jigs and fixtures are 3D printed in heat-resistant plastic.
3D printing makes designing and fabricating end-effectors easier and enables more complex, optimized solutions. 3D printed EOAT can increase efficiency and productivity — and can even speed up the design process.
The three main types of 3D printers are fused deposition modeling (FDM), stereolithography (SLA) and selective laser sintering (SLS). Each technology can be used for creating strong, customized, and effective end-of-arm-tooling, though each has unique strengths that lend themselves better to some applications.
FDM 3D printers excel at producing fast, inexpensive parts that are ideal for modeling and prototyping. For making mock-ups of end-of-arm-tooling to validate measurements or workflows, FDM is a great choice, and offers industry-familiar materials like ABS, so finite element analyses are possible. However, FDM 3D printers extrude filament layer by layer, creating minuscule air pockets in between layers in the Z direction — this can cause delamination when force is applied in that direction, and may make FDM EOAT components unsuitable in some contexts.
SLA 3D printers create parts by curing layers of liquid resin in the desired shape, layer by layer, with heat or light. The curing process creates isotropic parts, unlike FDM 3D printers, so SLA 3D printed EOAT can withstand multi-directional stressors equally. SLA 3D printers come in a range of build volumes and price points. Low-cost desktop resin printers are available for $200 to $1000, while professional options range from $2,500 to $10,000 and build volumes are more than suitable for the vast majority of end-of-arm-tooling components.
SLS 3D printers are being found more and more in manufacturing environments for 3D printed EOAT. The strength of SLS 3D printed parts and the material properties of nylon, the most common SLS material, streamlines SLS 3D printed EOAT’s integration into existing robotic systems. Additionally, elastomeric materials like Formlabs’ TPU 90A Powder are ideal for producing customized, geometrically complex soft grippers, one of the biggest applications for 3D printed EOAT.
Fused Deposition Modeling (FDM)Stereolithography (SLA)Selective Laser Sintering (SLS)
Resolution★★☆☆☆★★★★★★★★★☆
Accuracy★★★★☆★★★★★★★★★★
Surface Finish★★☆☆☆★★★★★★★★★☆
Throughput★★★☆☆★★★★☆★★★★★
Complex Designs★★★☆☆★★★★☆★★★★★
Ease of Use★★★★★★★★★★★★★★☆
ProsLow-cost consumer machines and materials
Fast and easy for simple, small parts
Great value
High accuracy
Smooth surface finish
Fast printing speeds
Range of functional applications
Strong functional parts
Design freedom
No need for support structures
ConsLow accuracy
Low details
Limited design freedom
Some materials are sensitive to long exposure to UV lightSlightly rough surface finish
Limited material options
ApplicationsConcept modeling
Rapid prototyping
Functional prototyping
Manufacturing aids
Concept modeling
Rapid prototyping
Rapid tooling
Manufacturing aids
Low volume, bridge, or custom manufacturing
Dental models and appliances
Medical models and medical devices
Jewelry prototyping and casting
Models and props
Rapid prototyping
Long-lasting, durable manufacturing aids
Medical devices, prosthetics, and orthotics
Print VolumeUp to 300 x 300 x 600 mm (desktop and benchtop 3D printers)Up to 353 x 196 x 350 mm (desktop and benchtop 3D printers)Up to 165 x 165 x 300 mm (benchtop industrial 3D printers)
MaterialsStandard thermoplastics, such as ABS, PLA, and their various blends.Varieties of resin (thermosetting plastics). Standard, engineering (ABS-like, PP-like, flexible, heat-resistant, rigid glass-filled), castable, and dental and medical (biocompatible). Pure silicone and ceramic.Engineering thermoplastics. Nylon 12, nylon 11, glass or carbon-filled nylon composites, polypropylene, TPU (elastomer).
TrainingMinor training on build setup, machine operation, and finishing; moderate training on maintenance.Plug and play. Minor training on build setup, maintenance, machine operation, and finishing.Moderate training on build setup, maintenance, machine operation, and finishing.
Facility RequirementsAir-conditioned environment or preferably custom ventilation for desktop machines.Desktop and benchtop machines are suitable for an office environment.Workshop environment with moderate space requirements for benchtop systems.
Ancillary EquipmentSupport removal system for machines with soluble supports (optionally automated), finishing tools.Washing station and post-curing station (both can be automated), finishing tools.Post-processing stations for powder management and part cleaning.
Equipment CostsBudget FDM printers and 3D printer kits start at around $200. Professional desktop FDM printers range from $2,000 to $8,000, and industrial systems are available from $15,000.Low-cost resin 3D printers are available for $200 to $1000, professional SLA 3D printers are in the $2,500 to $10,000 range, and large-format resin 3D printers are in the $5,000 to $25,000 range.Benchtop industrial SLS 3D printers start just under $30,000 for the printer and $60,000 for the entire ecosystem, including powder management and cleaning stations. Traditional industrial SLS printers start at around $200,000.
Material Costs$50-$150/kg for most standard filaments, and $100-$200/kg for support materials or engineering filaments.$100-$200/L for most standard and engineering resins, $200-$500/L for biocompatible materials.$100/kg for nylon. SLS requires no support structures, and unfused powder can be reused, which lowers material costs.
Labor NeedsManual support removal (can be mostly automated for industrial systems with soluble supports). Lengthy post-processing is required for a high-quality finish.Washing and post-curing (both can be mostly automated). Simple post-processing to remove support marks.Simple and semi-automated workflow for cleaning parts and recovering powder.
Step-By-Step Guide to Designing and 3D Printing EOAT
  1. Identify an area for improvement: e.g., paint hoses or weld torches that could be angled differently, grippers that need more flexibility, heavy components that could be optimized for lightweight strength, etc.
  2. Digitize existing tooling designs with reverse engineering to move to a digital inventory, or identify tooling needs and design new files.
  3. Leverage design process to add or remove material/weight where possible
    1. Take your existing file and remove weight where possible through generative design, hollowing, or creating lattice shapes.
      1. While not thinner than metal, SLA and SLS 3D printers enable more complex shapes and smoother finishes without additional machining, which can improve performance and reduce costs.
    2. Futureproof your parts by adding weight to surfaces that experience wear and tear or frequent friction.
  4. Combine disparate assembly components for improve efficiency through living hinges, snap fit joints, and complex geometries.
  5. Consider modularity and ergonomics for ease of installation and removal. Features like grips, contours, or screw threads can make installation and eventual replacement faster and easier.
  6. Export your design into a 3D printing software like Formlabs’ Preform, and select a material.
    1. Consider material demands like weight, stressors, impact-resistance, UV-resistance, chemical exposure, etc. Compare material properties and evaluate SLA resins and SLS powders for utility in your application.
  7. Send your part to the printer, post-process, and install your EOAT component.
3D Printing End-of-Arm-Tooling
SLA 3d printed eoat
SLA 3D printed EOAT like these white rollers help AMRC optimize the efficiency of their customers’ heavy industrial systems.
EOAT is essential for manufacturing systems to operate their robotic workflows efficiently and safely. Combined with other advanced technologies like artificial intelligence and improvements made to vision and sensing technology, 3D printing is shaping the future of automation.
Robots are becoming more capable and complex and need customized, advanced tooling that can match their gains in efficiency. Traditional EOAT, made from metal or injection molded plastics, can be heavy, cumbersome, or simplistically designed, leading to inefficiencies and unnecessary weight on the robotics systems.
3D printing presents an alternative to traditional methods of fabricating end-of-arm-tooling. 3D printed EOAT can be optimized for strength without adding weight, it can be produced quickly on-demand which increases agility and reduces downtime, and it can be iterated for process improvements and upgrades without adding high tooling costs to a manufacturer’s bottom line.
To test the strength of our 3D printed resins or powder, request a free sample. To get one of your EOAT components printed as a custom sample, contact our sales team.
