Calibrating the cartridge floor load cell (Form 4 and Form 4L generation)
Form 4 and Form 4L generation printers use a load cell in the cartridge floor to track the weight of the inserted resin cartridge during a print. This improves the accuracy of resin usage estimates and can speed up the resin dispensing process. If the printer is not accurately detecting how much resin is left in the resin cartridge, follow the instructions in this article to tare, or reset, the cartridge sensor.
To calibrate the cartridge floor load cell:
  1. On the touchscreen, tap Settings > Tools > Calibration > Cartridge load cell.
  2. Tap Start.
Starting the resin cartridge floor load cell calibration process on a Form 4 generation printer
  1. Remove the inserted resin cartridge(s) from the printer when prompted by the touchscreen.
Prompt to remove the resin cartridge when calibrating the resin cartridge floor load cell on a Form 4 generation printerPrompt to remove the resin cartridges when calibrating the resin cartridge floor load cells on a Form 4L generation printer
  1. Wait for the calibration process to complete. Do not reinsert the resin cartridge at this time.
Running the resin cartridge floor load cell calibration process on a Form 4 generation printer
  1. Tap Close when the calibration is complete.
    • If the taring process fails, ensure that nothing is touching the cartridge floor and restart the calibration tool.
Completing the resin cartridge floor load cell calibration process on a Form 4 generation printer
If you continue to experience issues with your printer not accurately measuring how much resin remains in the cartridges, contact Formlabs Support.
