Fast Cure time settings
The Formlabs Fast Cure helps 3D printed parts achieve their highest possible strength and stability. Optimal post-curing settings depend on equipment and the geometry of the part.
The table below indicates the recommended times to post-cure parts printed in Formlabs resins using the Fast Cure. Formlabs updates post-cure settings periodically with new and improved materials. Download the latest PDF version (English only) and check for updated post-cure settings when using a new resin or revised formulation.
Note:
For parts printed in a Formlabs resin for biocompatible applications, follow the post-curing steps in the relevant instructions for use or application guide.
Updating Fast Cure temperature settings
You can create and save up to nine custom post-cure profiles on the Fast Cure. Use these to update your machine when Formlabs releases new resins or to streamline your workflow.
Resin Post-cure timeLED intensityFlip parts
BEGO™ VarseoSmileⓇ TriniQⓇ ResinRefer to the Instructions for Use for washing and post-curing instructions for this resin. Enter the item number (REF) from the resin cartridge label to access the IFU.
BioMed Amber Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Black Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Clear Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed Durable Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
BioMed White Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Custom Tray Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Dental LT Clear Resin V2 Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Dental LT Comfort Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Denture Base Resin6 minutes7Yes
Denture Teeth Resin6 minutes7Yes
Draft Resin V21 minute5No
Fast Model Resin1 minute5No
Grey Resin V43 minutes9No
IBT Flex Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
IBT Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Model Resin V23 minutes9No
Model Resin V32 minutes9No
Permanent Crown Resin5 minutes1Yes
Precision Model Resin30 seconds2No
Premium Teeth Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Surgical Guide Resin Refer to the Manufacturing Guide for washing and post-curing instructions for this resin.
Temporary CB Resin5 minutes1Yes
White Resin V43 minutes9No
