Tip:
Over time, pigment in the colored resins (such as black or grey) may settle to the bottom of the container. Shaking the bottle before use ensures even color.
Before printing, refill the Form 1+ resin tank up to the maximum fill line. Each Form 1+ resin tank holds 200 mL of resin.
1. Shake the resin bottle
Tip:
2. Pour into resin tank
3. Fill to maximum line slowly
Filling the resin tank above the maximum fill line will damage the printer and void your warranty if resin overflows the tank during printing.
Larger prints may require that the resin tank is refilled during the print. With the printer paused, open the cover, and slowly add more resin to reach the maximum fill line.
Once the resin tank has been filled, you are ready to start your print.
