Note:
The intake fan runs whenever the printer is on, even when idle, so the filter can become clogged in between prints. When printing with nitrogen on a Fuse 1+ 30W printer, the intake fan is not used.
Fuse 1 generation printers maintain certain pressure values inside the printer to move air or nitrogen and to filter out powders and byproducts of the sintering process. During preprint, Fuse 1 and Fuse 1+ 30W units check whether pressure is within expected levels. If these checks fail, an error appears on the printer touchscreen.
Unexpected pressure values do not result in errors or terminated prints, except for Fuse 1+ 30W units printing with nitrogen. Fuse 1+ 30W units printing with nitrogen check pressure levels regularly, which can lead to one of these errors during a print.
The table below shows approximate expected pressure readings under normal conditions:
| Fuse 1 | Fuse 1+ 30W (air) | Fuse 1+ 30W (nitrogen) | |
| Intake | 128 Pa | 128 Pa | 120–135 Pa |
| Print enclosure | -5 Pa | 180 Pa | 180 Pa |
| Nitrogen pressure | N/A | Varies | 234–827 kPa |
Symptoms
Causes
Troubleshooting steps
Collect some basic information about the error message. This may help with your troubleshooting or when contacting Formlabs Support or a certified service provider.
If the error persists after troubleshooting, contact Formlabs Support or a certified service provider for additional assistance. If possible, provide the printer history or enable Dashboard Logging and recreate the issue so the printer logs can be reviewed.
Intake pressure too low
Fuse 1 intake blower ducts
Fuse 1+ 30W intake blower duct
Note:
Replace the nitrogen ball valve (Fuse 1+ 30W only)
The Fuse 1+ 30W nitrogen ball valve determines which inlet source is in use. If this valve fails to open or close properly, the unit measures a pressure value near zero, as the flow is blocked.
Error 195
Ensure the printer’s firmware is up to date. If the firmware is up to date, reflash the currently installed firmware.
Error 196
Note:
Error 197
Error 197 appears in N2 Mode when the printer cannot keep the intake or chamber pressure within the expected range. This usually happens because the recirculation (exhaust) fan is not running reliably at low speeds. To resolve this error:
Note:
If you need to print urgently, switching to Air Mode may allow you to continue. Note that Formlabs does not generally recommend printing certain powders without nitrogen.
On Fuse 1 printers, Error 197 may indicate that the exhaust fan was reinstalled backwards after cleaning. The Fuse 1 normally holds a slightly negative pressure in the print enclosure, but installing the exhaust fan backwards will pressurize the enclosure instead. Unmount the fan, turn it over, reinstall it, and try again.
