Tip:
Slider position and whether the view axis is flipped is controlled separately for each axis.
To ensure a FORM file’s printability, check your model for unsupported minima and possible suction cups, then inspect individual layers with the Slicer tool in PreForm.
Use the Slicer tool to see inside your model from any orthogonal direction, ensuring a perfect print every time. This is perfect for verifying internal support placement while you work, as the slice view is active while you move, rotate, or edit supports.
Controlling theSlicertool
Starting with PreForm version 3.52.0, you can use the Slicer tool to section your models from any orthogonal direction. In previous versions of PreForm, you could only view your models in layers along the Z-axis, from the bottom up. To configure the Slicer tool, click the buttons underneath the slider on the right side of the 3D scene:
Tip:
Inspecting individual slices
To inspect sections of your models with the Slicer tool:
Jumping to a specific point within your models
To view a particular layer or spot within your models with the Slicer tool:
