Tip:
PreForm downloads and release notes Firmware downloads and release notesInstalling PreForm software
Get started with your Formlabs 3D printer by downloading PreForm software. Importing an STL/OBJ/3MF file into PreForm is the first step to supporting and orienting a digital 3D model in preparation of printing.
PreForm is supported on the following operating systems:
- Windows 10 64-bit (version 1809) or later
- macOS 10.12 or higher
If your computer is using an unsupported operating system, install PreForm 2.16 for 32-bit operating systems.
Fuse 1
To install PreForm on your computer to use with a Fuse 1 printer:
- Visit formlabs.com/software.
- Click the Download button for your computer's operating system. An EXE or DMG file downloads.
- Open your Downloads folder.
- Double-click the file named
Preform_setupto begin installing PreForm. A setup window opens. - Follow the prompts to finish installing.
- Update your Fuse 1 firmware.
- Import a model into PreForm to begin printing with your Fuse 1.
TIP:
Update your graphics card driver to ensure optimal performance.
Formlabs SLA printers
To install PreForm on your computer to use with a Formlabs SLA printer:
- Update your Form 3L/Form 3BL firmware.
- Import a model into PreForm to begin printing with your Form 3L/Form 3BL.
TIP:
Form 1 and Form 1+
To install PreForm on your computer to use with a Form 1+ printer:
- Download PreForm 2.20:
- Preform_setup_2_20.exe for Windows users.
- PreForm_2_20.dmg for Mac users.
- Double-click the downloaded file to begin installing PreForm. A setup window opens.
- Update your Form 1+ firmware to version 1.40.
- Import a model into PreForm to begin printing with your Form 1+.
PreForm 2.20.0 is the last supported version for the Form 1+. Refer to the support article Using PreForm with the Form 1+ for more information.
Manual PreForm updates
PreForm automatically checks for updates if the computer is connected to the internet. When updates are available, PreForm prompts you with the option to download and install the latest version.
To manually check for updates in PreForm:
- In the PreForm menu bar, click Help > Check For Updates…. The PreForm Update Check box appears while PreForm checks for updates.
- If updates are available, follow the prompts to download and install the new version of PreForm.
TIP:
For an overview of new features in a PreForm installation, click Help > What’s new? in the PreForm menu bar.
32-bit support
PreForm versions 2.17.0 and later only support 64-bit operating systems. Users on 32-bit operating systems can continue using PreForm version 2.16.0, the final 32-bit release. While PreForm feature updates and bug fixes are available for 64-bit releases only, Formlabs maintains materials updates for the 32-bit PreForm 2.16.0 release.
