Printing with the Build Platform 2L
The Build Platform 2L enables a quick and controlled release of printed parts from the build platform, allowing for an easier and more reliable post-processing workflow.
When using the Build Platform 2L, make sure that both the build platform and your models are properly prepared before printing. Ensure that the build platform is clean and properly assembled. Certain part orientations and support options release more easily from the build platform than others, so set up your print with this in mind.
For the best print results:
Build Platform 2L technical illustration annotating the print surface and build platform body.
Build Platform 2L
The Build Platform 2L is made of two components: the build platform body and the print surface. The print surface is attached to the build platform body with magnets positioned within the alignment channels and throughout the top surface of the build platform body. The print surface bends when you push the part release paddles inwards, causing printed parts to release for easier post-processing.
Printing with Formlabs resins
  • The Build Platform 2L is approved for use with Formlabs resins for biocompatible applications. Always follow the Instructions for Use when using Formlabs resins to produce biocompatible parts. For full compliance with biocompatibility requirements, the Build Platform 2L should not be used with any other resins.
  • The Build Platform 2L is not compatible with Durable Resin, Flexible 80A Resin, and Elastic 50A Resin. Use the standard build platform for these resins.
  • If you experience issues with print reliability, fine-tune the Z-axis of your printer.
Inspecting the print surface
Before printing with the Build Platform 2L:
  1. Inspect the build platform and make sure that it is clean and dry.
  2. Check that the print surface is flat and properly aligned with the build platform body.
  3. Actuate the part release tabs closest to you and check that the two alignment rods are fully seated in their respective alignment channels.
The Build Platform 2L is shown in profile with the flexible print surface flat and aligned with the build platform body.
The Build Platform 2L is shown in profile with the flexible print surface misaligned.
Printing with an improperly assembled Build Platform 2L can damage the build platform, your resin tank, or your printer.
Preparing your models in PreForm
Step 1: Orient models perpendicular to the front of the build platform
Align the long edge of the models perpendicular to the bend axis of the build platform so that parts are more likely to release. Place models perpendicular to the front of the build scene for easy part removal as the surface flexes.
A model is shown in PreForm with the long edge perpendicular to the front of the build scene.
A model is shown in PreForm with the long edge parallel to the front of the build scene.
Step 2: Overlap support rafts on smaller parts
Parts that are three centimeters at their longest point may be too small to completely release from the build platform when the surface flexes. Place these models close together in PreForm so that their rafts overlap and create a larger surface area. If you are using the automatic layout tools in PreForm, check the Overlap Rafts box in the Layout window.
Eight models are placed close together in PreForm with overlapped support rafts.
Eight models are placed seperately in PreForm with no overlapped rafts.
Note:
Avoid using mini-rafts with the Build Platform 2L. The surface area on mini-rafts is too small to release from the print surface when it bends.
Step 3: Print parts with large flat surfaces directly on the build platform
Printing parts directly on the build platform can reduce print time and resin consumption, as well as simplifying post-processing steps.
Parts printed directly on the Build Platform 2L.
Removing parts from the Build Platform 2L
Warning:
Wear gloves when handling printed parts and surfaces that are contaminated with solvent or liquid resin to prevent skin contact.
Caution:
Do not point the print surface of the Build Platform 2L toward your face. Flying parts or debris may lead to injury.
The Build Platform 2L’s print surface bends, releasing printed parts for post-processing. Released parts may separate entirely from the build platform or remain partially adhered due to liquid resin, allowing them to be removed by hand.
Remove the build platform from the printer and wash the attached parts using your solvent of choice.
For large parts:
  1. After washing, place the build platform on a flat work surface with the printed parts facing up.
  2. Loop fingers into the handles to keep the platform stable.
  3. Gradually push both part release tabs inwards with your thumbs.
  4. Parts separate from the build platform as the surface bends.
The Build Platform 2L is place flat on the work surface. Two hands push both part release tabs inwards to release the large part.
For smaller parts:
  1. Place the build platform on its side with the printed parts facing away from you.
  2. For better control during part removal, cover the parts with a paper towel to contain them.
  3. Gently press down on the top two part release tabs towards the center of the build platform.
The Build Platform 2L is placed on its side with the printed parts facing away. Two hands push both part release tabs downwards to release the small part.
For large or fragile parts:
  1. Place the Build Platform 2L flat on your work surface.
  2. Support the printed part with one hand.
  3. Push one part removal tab at a time to better control the release.
If parts remain on the build platform, use a part removal tool or scraper to manually remove them or pull them off with a gloved hand.
Clean the print surface if you plan to print again with the same resin, or thoroughly clean the entire Build Platform 2L to completely remove all traces of resin before printing with a different material.
Store the build platform inside the printer or somewhere out of direct sunlight.
Other removal methods may be effective, depending on your part geometry. Experiment to find the method that works best for your parts and your workflow.
Troubleshooting with the Build Platform 2L
Non-adherence
When printing solid rectangular parts, the print surface may flex or decouple due to the internal stresses of the printing process. If this occurs, do not print the part directly on the build platform. Add support rafts to prevent the part from decoupling from the Build Platform 2L during the printing process.
A rectangular model is shown in PreForm with support rafts.
A rectangular model is shown in PreForm directly on the build scene.
Warped parts
Printing large parts directly on the build platform surface near the short edges may cause warping. If this occurs, do not print the part directly on the build platform. Add support rafts and reorient the part to prevent warping.
Two rectangular models are shown in PreForm with support rafts.
A rectangular model is shown at the edges of the build scene in PreForm.
Mixer decoupling
The Build Platform 2L print surface attaches to the build platform body using magnets positioned within the alignment channels and throughout the surface of the build platform body.
If the printer experiences a Mixer Error due to a high volume of resin or particularly viscous resins like Rigid 10K or BioMed Clear, the magnets in the build platform may pick up the decoupled mixer. The printer pauses the print when this happens and displays an error message.
If the printer experiences mixer decoupling when printing with the Build Platform 2L, follow these steps:
  1. Mix the resin well prior to printing.
  2. Update the printer’s firmware to the latest version.
  3. Remove the build platform and inspect it for cured resin or other debris.
  4. Remove the resin tank and place it in its case.
  5. Reseat the mixer.
  6. Using the tank tool, inspect the resin tank film for cured resin or other debris. If you find any cured resin, remove it using the tank tool.
Do not use the part removal tool, scraper, flush cutters, or any other metal tool to inspect the resin tank or remove cured resin from the tank. These tools may damage the tank film, leading to failed prints or resin spills.
  1. Reinsert the resin tank and build platform.
  2. On the printer touchscreen, tap the gear icon. The Settings screen appears.
  3. Tap Maintenance. The Maintenance screen appears.
  4. Tap Calibration. The Calibration screen appears.
  5. Tap Calibrate Tank Mixer Sensor and follow the onscreen prompts to calibrate the tank mixer sensor.
If the mixer moves incorrectly or erratically, or fails to park, be sure that you are inserting the mixer correctly: magnet side down, with the arms pointing to the right. If the arms or magnets are damaged or missing, the mixer may not move properly.
  1. Restart the print.
