Removing Wi-Fi hardware (Fuse 1 generation)
Fuse 1 generation printers have Wi-Fi functionality for receiving print jobs and firmware updates and uploading log files. Wi-Fi can be turned off via the printer's touchscreen, but depending on your organization's security requirements, you may need to physically remove the Wi-Fi hardware before using the printer. This hardware includes a component on the system on a module (SOM) plugged into the motherboard as well as one or two Wi-Fi antennas plugged into the SOM.
Use this guide to remove all Wi-Fi hardware from a Fuse 1 generation printer.
Fuse 1 generation SOM
Required supplies:
Third-party:
  • 1.5 mm hex driver (flat-end)
  • 3 mm hex driver (must have a 90º head)
  • ESD-safe spudger (recommended) or ESD-safe tweezers
  • ESD-safe small plastic bag (optional)
  • Hot rework tweezers or other SMD soldering equipment
  • Antistatic wrist band
  • Safety glasses
  • Nonreactive nitrile gloves
  • 99% ethanol or 99% isopropyl alcohol
  • Microfiber cloth
Estimated time: 60–75 minutes
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for modifying the SOM.
Step 1: Prepare the workspace
Step 2: Unplug the printer
Danger:
Removing the display assembly
Overview: Remove the display assembly to access the motherboard and SOM.
Step 1: Remove the display assembly
Follow the instructions for your printer type to uninstall the display assembly. Do not separate the motherboard from the display, but remember to unplug the Wi-Fi antenna cable(s) from the SOM.
Removing the original SOM
Overview: Uninstall the original SOM from the motherboard.
Step 1: Remove the SOM retention screws
Using a 1.5 mm hex driver, loosen and remove the two 5 mm M2 socket head screws securing the SOM to the motherboard. Set the screws aside.
Remove the SOM
Step 2: Locate the SOM retention tabs
Remove the SOM
Remove the SOM
Locate the two retention tabs (one on each side) securing the SOM to the motherboard.
Step 3: Open the retention tabs
Use an ESD-safe spudger or a pair of ESD-safe tweezers to disengage the retention tabs by flexing them outwards slightly. The end of the SOM opposite the socket may lift up slightly.
Remove the SOM
Step 4: Remove the SOM
Gently grip the SOM by the heat sink, pivot it upwards at approximately a 30º angle, then pull it straight away from the motherboard.
Remove the SOM
Modifying the SOM
Overview: After removing the SOM from the printer, remove component L13.
Step 1: Prepare to modify the SOM
If you have not already, put on an antistatic wrist band and connect it to a known ground point. Do not connect the wristband any surfaces that are powder-coated or painted. Prepare a pair of hot rework tweezers or appropriate SMD soldering equipment, as well as any necessary personal protective equipment.
Step 2: Unscrew and remove the heatsink
Modifying the SOM
Modifying the SOM
Using a 1.5 mm hex driver, unscrew and remove the four screws securing the heatsink to the SOM. Set the screws aside. Remove the heatsink and set it aside fins down.
Step 3: Remove component L13
Using hot tweezers or other appropriate SMD soldering equipment, remove component L13 from the SOM. If you plan to reverse this procedure in the future, save component L13 for later reuse in an ESD-safe bag.
Modifying the SOM
Step 4: Reinstall the heatsink
Modifying the SOM
Modifying the SOM
Put on a pair of clean, nonreactive nitrile gloves. Use a microfiber cloth wetted with a small amount of ethanol to wipe any contaminants off of the flat heatsink face.
Reinstall the heatsink onto the SOM, making sure the thermal pad on the bottom of the heatsink covers the processor (the largest chip on the board, labeled U6). Ensure that the cutout on the edge of the heatsink allows access to the two Wi-Fi antenna ports and that the screw holes in the heatsink align with the holes in the SOM.
Insert one 3 mm M2 screw into each of the four screw holes in the heatsink. Using a 1.5 mm hex driver, tighten the four screws until finger tight. Do not overtighten.
Reinstalling the SOM
Overview: Insert the modified SOM into its slot on the motherboard and secure it in place.
Step 1: Insert the SOM into its socket
Install the replacement SOM
Pick up the SOM by the heatsink, then insert it into the socket on the motherboard at approximately a 30º angle. Gently push the SOM into the socket so that none of the gold pins on the SOM are visible.
Step 2: Secure the SOM with the retention tabs
Push the SOM down onto the motherboard until the retention tabs snap into place.
Step 3: Fully secure the SOM
Thread one 5.0 mm M2 screw into both of the two screw holes in the SOM. Using a 1.5 mm hex driver, tighten until finger-tight.
Reinstalling the display assembly
Overview: After reinstalling the SOM, reinstall the display assembly.
Step 1: Reinstall the display assembly
Follow the instructions for your printer type to reinstall the display assembly. Do not reattach the Wi-Fi antenna cable(s) to the SOM
Finalizing the repair
Overview: After installing the modified SOM, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the repair
Start a print. Monitor the printer to ensure that the print proceeds normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
