Replacing the Form 3 LevelSense board
The LevelSense board senses the position of the float in the resin tank, which the printer uses to determine the amount of resin in the tank. The LevelSense board sits at the back of the printer, at the base of the Z-tower. A malfunctioning LevelSense board will prevent the printer from printing properly.
Use this guide to replace the Form 3 LevelSense board.
Required Supplies:
  • LevelSense board
Third-party:
  • 3 mm hex driver
  • 2.5 mm hex driver
  • 2 mm hex driver
  • T8 Torx driver
  • T10 Torx driver
  • Nitrile gloves
Estimated time: 20–30 minutes
DANGER:
Preparing the workspace
Overview: Prepare the Form 3 and a dust-free workspace for replacing the LevelSense board.
NOTICE:
The LevelSense board is a sensitive electronic component. Do not remove the LevelSense board from its packaging until instructed.
Remove the build platform first to avoid dripping resin onto the LPU or into the printer cavity.
Step 3: Remove and store the resin tank
Remove the resin tank, place it in the resin tank carrier, and cover it with its lid. Set the carrier and tank aside on a clean, flat surface.
NOTICE:
Step 4: Prepare the workspace
Clear a workspace around your printer. Ensure that the workspace is well-ventilated and free of dust. Prepare additional space for storing the rear panel of the printer during maintenance.
Step 5: Clean the printer cavity
WARNING:
Open the printer cover. Clean any resin pooled on the printer floor, inside the printer cavity, with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Removing the rear shell
Overview: Remove the rear shell of the printer to gain access to the LevelSense board.
NOTICE:
The Form 3 contains sensitive electronic components. Ground yourself before touching any electronics in the printer by using a grounding strap or touching a grounded piece of metal.
Step 1: Remove the rear shell screws (internal)
Open the printer cover. There is one screw on each side of the Z-tower. Depending on the age of your printer, they may be 2 mm hex screws or T10 Torx screws. Use the appropriate driver to loosen and remove the two screws on the side of the Z-tower.
Step 2: Remove the rear shell screws (external)
Rotate the printer to access the rear. Use a 3 mm hex driver to loosen and remove the two screws on the back of the printer, near the power and data ports.
Step 3: Remove the rear shell
Gently flex the sides of the rear shell outwards to unclip it from the printer frame. Pull the rear shell directly away from the printer to remove it. Set the rear shell aside.
Locate—but do not remove—the two nuts, retained in the lower shell, that previously secured the external rear shell screws. Ensure that they did not come loose while removing the rear shell.
Removing the side shell
Overview: Unscrew and remove the side shell on the same side of the printer as the LevelSense board.
Step 1: Remove the side shell screws
Lay the printer gently on its back. Remove the two screws holding the left side shell onto the printer with the 2.5 mm hex key.
Step 2: Remove the side shell
Gently pull the side panel towards the bottom of the printer. It should easily slide free. Set the side panel aside and lift the printer upright again.
Removing the LevelSense board
Overview: Unplug, unscrew, and remove the LevelSense board from the printer.
Step 1: Lift the top shell
The black plastic top shell surrounds the tank carrier and printer cavity. To access the LevelSense board more easily, the rear end of this shell must be lifted out of the way.
Unclip one side of the top shell from the frame by pulling the clips (circled in the image below) straight out away from the printer body.
Then, bend the shell upwards gently to reveal the LevelSense board. Do not bend sharply or the top shell may be damaged.
NOTICE:
Do not fully remove the top shell. The tank tensioner, located underneath the other side of the top shell, is not serviceable. Modifying the tensioner may result in personal injury or damage to the machine.
Step 2: Remove the retaining screws
Use the T8 Torx driver to loosen the two Torx screws that attach the LevelSense board to the printer frame. Remove the screws and their plastic spacers.
Step 3: Disconnect the LevelSense cable
Locate the LevelSense board cable. Hold the connector by its plastic housing and disconnect the cable from the LevelSense board. Do not pull on the individual wires.
Step 4: Remove the LevelSense board
Carefully remove the LevelSense board from the printer. Pull gently by the connector and exposed edge of the board.
Installing the new LevelSense board
Overview: After removing the old LevelSense board, connect and install the replacement LevelSense board.
Step 1: Mount the LevelSense board
Place the new LevelSense board on the two plastic posts. Press the board towards the front of the printer to ensure that it is seated flush against the printer frame.
Step 2: Reconnect the LevelSense cable
Plug the LevelSense cable into the LevelSense board. The cable will only enter the connector in the correct orientation. Be careful not to bend the pins in the connector.
Step 3: Install the LevelSense screws
Place the plastic spacers on the LevelSense board screws. Screw both screws back in using the T8 Torx driver. Do not overtighten to avoid stripping the screw threads.
Reinstalling the shells
Overview: After installing the replacement LevelSense board, reinstall and secure the shells.
Step 1: Secure the top shell
Press the top shell downward onto the frame until the retaining clips click into place.
Step 2: Replace the side shell
Lay the printer gently on its back. Align the four pins on the side panel with the corresponding slots on the printer frame.
Press the side shell inward, toward the printer body, and slide it toward the top of the printer. When the side shell is fully seated, there is no gap between the side shell and the other printer shells.
Step 3: Secure the side shell
Using the 2.5 mm hex driver, screw the two 2.5 mm hex screws into the side shell of the printer.
Reinstalling the rear shell
Overview: After performing any other maintenance procedures, reinstall and secure the rear shell.
Step 4: Replace the rear shell
Place the rear shell back onto the printer. Press it towards the front of the printer to ensure that it fully seats in place. There should be no gaps between the rear shell and the side or bottom shells.
Step 5: Secure the rear shell
Using a 3 mm hex driver, screw the two 3 mm hex screws into the rear of the printer.
Open the printer cover. Using a 2 mm hex driver or a T10 Torx driver (depending on the type of screws in your printer), screw the two Z-tower screws into the sides of the Z-tower.
Finalizing the repair
Overview: After installing the new LevelSense board, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer cover and connect the power cable to the printer and the power supply. The printer will initialize. If the printer reports that its cover is open, repeat this maintenance procedure and ensure that the LevelSense cable is fully plugged into the new LevelSense board.
