Required Supplies:
- Cartridge dispense spring
Third-party:
- 3 mm hex driver
- 2 mm hex driver
- T10 Torx driver
- Nitrile gloves
- Paper towels
- Needle nose pliers or tweezers
The resin dispense arm sits at the bottom of the resin cartridge slot at the back of the Form 3. When activated, it presses into the cartridge bite valve to dispense resin. A spring automatically retracts the arm when not in use so that resin is not dispensed inadvertently. A weak or damaged cartridge dispense spring can allow too much resin to be dispensed, leading to overfilled resin tanks and resin spills.
Use this guide to replace the Form 3 cartridge dispense spring.
Required Supplies:
Third-party:
Estimated time:20 minutes
Preparing the workspace
Overview: Prepare the Form 3 and a dust-free workspace for replacing the cartridge dispense spring.
Remove the build platform first to avoid dripping resin into the printer cavity.
Step 3: Remove and store the resin tank
Remove the resin tank, place it in the resin tank carrier, and cover it with its lid. Set the carrier and tank aside on a clean, flat surface.
NOTICE:
Step 4: Prepare the workspace
Step 5: Unplug the printer
Disconnect the power cable from the printer before continuing with maintenance. Do not perform maintenance on the printer while it is connected to power. Wait five minutes after disconnecting the printer from power before proceeding.
DANGER:
Removing the rear shell
Overview: Remove the rear shell of the printer to gain access to the resin cartridge slot.
NOTICE:
The Form 3 contains sensitive electronic components. Ground yourself before touching any electronics in the printer by using a grounding strap or touching a grounded piece of metal.
Open the printer cover. There is one screw on each side of the Z-tower. Depending on the age of your printer, they may be 2 mm hex screws or T10 Torx screws. Use the appropriate driver to loosen and remove the two screws on the side of the Z-tower.
Rotate the printer to access the rear. Use a 3 mm hex driver to loosen and remove the two screws on the back of the printer, near the power and data ports.
Step 3: Remove the rear shell
Gently flex the sides of the rear shell outwards to unclip it from the printer frame. Pull the rear shell directly away from the printer to remove it. Set the rear shell aside.
Locate—but do not remove—the two nuts, retained in the lower shell, that previously secured the external rear shell screws. Ensure that they did not come loose while removing the rear shell.
Removing the cartridge slot plate
Overview: Remove the plate that covers the resin cartridge slot to gain access to the cartridge dispense spring.
Use a 2 mm hex driver to loosen and remove the four screws holding the cartridge slot plate to the Z-tower.
Step 2: Remove the cartridge slot plate
Remove the cartridge slot plate and set it aside.
Removing the cartridge dispense spring
Overview: Clean the cartridge floor and remove the cartridge dispense spring from the printer.
Step 1: Clean the cartridge floor
Absorb any resin on the cartridge floor with a clean paper towel.
NOTICE:
Do not use any solvents to clean the cartridge floor. Any solvent on the cartridge floor can contaminate resin dispensed during subsequent prints.
Use the 2 mm hex driver to loosen and remove the three screws that secure the cartridge spring finger assembly to the bottom of the cartridge slot.
Move the cartridge spring finger assembly to the side to access the cartridge dispense spring. Do not unplug the cartridge spring finger assembly.
Step 3: Remove the cartridge dispense spring
The cartridge dispense spring is attached to the resin dispense arm and to a metal tab on the cartridge floor. Gently remove the spring from the metal tab using needle nose pliers, tweezers, or another similar tool.
Remove the other end of the spring from the dispense arm. Set the spring aside.
Installing the new cartridge dispense spring
Overview: After removing the old cartridge dispense spring, install the replacement cartridge dispense spring.
Slip the ends of the cartridge dispense spring over the hook on the resin dispense arm and over the metal tab on the cartridge floor using needle nose pliers, tweezers, or another similar tool.
Push the dispense arm to extend the cartridge dispense spring. Release the dispense arm and ensure that the spring fully retracts.
Place the three 2 mm hex screws into their respective holes in the cartridge spring finger assembly and thread them into the floor of the cartridge slot. Tighten the three screws using the 2 mm hex driver. Do not overtighten to avoid stripping the screw threads.
Reinstalling the cartridge slot plate and rear shell
Overview: After installing the replacement cartridge dispense spring, reinstall and secure the cartridge slot plate and rear shell.
Orient the cartridge slot plate vertically, with the cutout at the top. Align the four holes in the cartridge slot plate with the four screw holes in the Z-tower.
Thread one 2 mm hex screw into each of the four holes. Tighten the screws using a 2 mm hex driver. Do not overtighten to avoid stripping the screw threads.
Place the rear shell back onto the printer. Press it towards the front of the printer to ensure that it fully seats in place. There should be no gaps between the rear shell and the side or bottom shells.
Using a 3 mm hex driver, screw the two 3 mm hex screws into the rear of the printer.
Open the printer cover. Using a 2 mm hex driver or a T10 Torx driver (depending on the type of screws in your printer), screw the two Z-tower screws into the sides of the Z-tower.
Finalizing the repair
Overview: After installing the new cartridge dispense spring, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer cover and connect the power cable to the printer and the power supply. The printer will initialize.
Step 2: Test the printer
Insert a resin cartridge into the printer and check that the printer detects it properly. Insert a resin tank and build platform, then start a print and check that the printer dispenses resin properly.
