Replacing the Form 4 camera
Form 4 generation printers contain an integrated camera. If the camera is enabled, it automatically saves a photo of each print when it completes. Any issues with the camera may prevent it from working properly.
Use this guide to replace the Form 4 camera.
Required Supplies:
  • Camera
  • 2.5 mm hex driver (included in the Form 4 tool caddy)
  • 2 mm hex driver (included in the Form 4 tool caddy)
Third-party:
  • Nitrile gloves
  • T10 Torx driver
Form 4 camera replacement part
Estimated time: 20 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the camera.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the back panel
Overview: Remove the back panel to access the camera.
Formlabs printers contain sensitive electronic components. Ground yourself before touching any electronics in the printer by using a grounding strap or touching a grounded piece of metal.
Step 1: Remove the back panel screws
Remove the Form 4 back panel screws
Use a 2.5 mm hex driver to remove the eight screws securing the back panel to the printer. Set the screws aside.
Step 2: Remove the back panel
Form 4 back panel removed
Remove the back panel by sliding it down and away from the back of the printer. Set the back panel aside.
Removing the camera
Overview: Disconnect the cable that connects the camera to the printer and remove the screws securing the camera.
Step 1: Disconnect the camera ribbon cable
Disconnect the Form 4 camera ribbon cable
Pull each side of the black plastic tab on the connector to unlatch the camera ribbon cable. Gently pull the ribbon cable away from the camera. The ribbon cable should slide out of the connector.
Take care when unplugging the cable to avoid damage. Once the plastic tab is released, the cable should easily slide off the connector.
Step 2: Remove the camera mounting screws
Remove the Form 4 camera mounting screws
Use a T10 Torx driver to remove the two screws securing the camera to the printer. Set the screws aside.
Step 3: Remove the camera
Slide the camera out of the printer and set it aside for disposal.
Installing the replacement camera
Overview: Reconnect the camera ribbon cable and replace the screws securing the camera.
Step 1: Insert the camera
Slide the camera into the printer and line up the screw holes.
Step 2: Replace the camera mounting screws
Use a T10 Torx driver to secure the two screws securing the camera to the printer.
Step 3: Reconnect the camera ribbon cable
Reconnect the Form 4 camera ribbon cable
Reinstalling the back panel
Overview: After replacing the camera, reinstall and secure the back panel.
Step 1: Mount the back panel
Mount the Form 4 back panel
Slide the top edge of the back panel under the cover bracket. Ensure that the eight screw holes in the back panel align with the corresponding holes in the printer and the back panel sits flush with the sides of the cover.
Step 2: Secure the back panel
Secure the Form 4 back panel screws
Thread one back panel screw into each of the eight screw holes in the back panel. Use a 2.5 mm hex driver to tighten until snug.
Finalizing the repair
Overview: After replacing the camera, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the camera
Start a print and test the camera functions, such as the timelapse, to check that the replacement was successful. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
