Replacing the Form 4 leveling feet
Form 4 generation printers have four adjustable feet that raise the printer off the work surface and allow it to be leveled before printing. If one or more of the leveling feet is damaged or missing, it may be difficult to keep the printer level.
Use this guide to replace the leveling feet.
Form 4 generation leveling foot
Required Supplies
Provided by Formlabs
  • Leveling feet
Third party
  • Nitrile gloves
Estimated time: 5 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the leveling feet.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Clear a workspace around your printer. Ensure that the workspace is well-ventilated and free of dust. Prepare additional space for storing the back panel of the printer during maintenance.
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Replacing the leveling feet
Overview: Rotate the printer so that it lies on its back, remove the leveling feet, and install the new leveling feet.
Step 1: Rotate printer
Rotate the printer so it lies flat on its back with the bottom facing you.
Step 2: Remove leveling feet
Remove the damaged leveling feet, if present, by rotating them counterclockwise until they come loose.
Step 3: Install leveling feet
Install the replacement leveling feet by threading them into the holes clockwise.
Finalizing the repair
Overview: After installing the replacement leveling feet, power on the printer and perform final checks.
Step 1: Power on the printer
Stand the printer upright and connect the power cable to the printer and the power supply. Turn on the switch at the back of the printer. The printer turns on and initializes.
Step 2: Level the printer
Follow the instructions in the support article Leveling Formlabs SLA printers to level the printer. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
