Replacing the Form 4L Light Processing Unit 4L (LPU 4L)
In Form 4L generation printers, the printer’s backlight shines through a component called the Light Processing Unit 4L (LPU 4L) to print. The LPU 4L contains an LCD panel, heaters, and sensors that form an important part of the Form 4L optical system. The LPU mounts to the Form 4L and sits under the resin tank. A malfunctioning LPU can prevent the printer from printing properly.
Use this guide to replace the Light Processing Unit 4L (LPU 4L).
Required Supplies:
  • Light Processing Unit 4L (LPU 4L)
  • 3 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Nitrile gloves
Estimated time: 15–30 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the LPU.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off of the bite valves and into the printer.
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
Removing the LPU
Overview: Loosen the housing screws and remove the LPU.
NOTICE:
This step involves removing the LPU, which exposes the Form 4L optical system. While the LPU is removed from the printer, ensure that no dust or debris falls into the optical cavity.
Step 1: Loosen the LPU housing screws
Open the printer cover. Use a 3 mm hex driver to loosen the eight captive hex screws in the LPU housing.f4l-lpu-screws.jpg
Step 2: Unplug the HDMI cable
Carefully lift the LPU and tilt it so that the bottom faces you. Locate the LPU’s HDMI cable. Squeeze the plastic retaining clip and unplug the HDMI cable from the LPU.
Step 3: Disconnect the tank heater cables
On both sides of the printer, the heater cables are oriented with the clip facing outwards. Release the tank heater cables by squeezing the tab on the connectors and pulling directly away from the LPU. Do not pull on the cable itself.
Step 4: Remove the LPU
Remove the LPU from the printer and set it aside for disposal with electronic waste.
Installing the replacement LPU
Overview: After removing the old LPU, connect and install the replacement.
Step 1: Connect the tank heater cables
Position the LPU so the cable connectors are oriented towards the front of the printer. Plug the tank heater cables into the connectors on the LPU. The plastic tab should click into place to secure the cable.
Step 2: Connect the HDMI cable
Plug the HDMI cable into the port on the LPU. Ensure that the two prongs on the plastic retaining clip snap into place.
Step 3: Mount the LPU
Ensure that the optical cavity and LPU are free from dust and debris. Place the LPU onto the optical cavity and align the screw holes.
Step 4: Thread the housing screws
Use a 3 mm hex driver to loosely thread the eight captive hex screws in the LPU housing.
Step 5: Secure the LPU
Once all screws are loosely threaded, tighten the screws in a diagonal pattern as shown above. The screws should be secure but not overtightened. To avoid overtightening, grip the short end of the hex driver.
Finalizing the repair
Overview: After installing the replacement LPU, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer cover and connect the power cable to the printer and the power supply. Turn on the switch at the back of the printer. The printer initializes.
Step 2: Check the printer optics
Check that the LPU is functioning properly and nothing is blocking the optical path.
Dim the lights in your workspace. This will make it easier to see the light from the Backlight Unit and determine if it is working properly. Place a sheet of paper on the LPU to protect your eyes from UV damage. Leave the printer cover open after placing the sheet of paper on the LPU.
On the touchscreen, go to Settings > Tools > Inspect optics. Follow the on-screen instructions. Inspect the paper. If the Backlight Unit and LPU are functioning normally, the paper should be uniformly dimly lit. If the paper does not appear to light up at all, the environment may be too bright. Turn down the lights or use thinner paper, then inspect the backlight again. If the LPU is not functioning properly, check the cable connections.
Tap Done to turn off the Backlight Unit and LPU and finish the test.
Step 3: Align the build platform
On the touchscreen, tap Settings > Tools > Align build platform. Follow the on-screen instructions.
Step 4: Run a test print
Insert any missing consumables and upload and start a print. Check that the print starts normally and the parts print successfully. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
