Replacing the Form 4L diffuser panel
The diffuser panel lies sandwiched between the Backlight Unit and the Light Processing Unit (LPU) on Form 4L generation printers. It evenly distributes the light from the Backlight Unit and is necessary for a functioning optical system. A damaged diffuser panel may prevent the printer from printing properly.
Use this guide to replace the diffuser panel on a Form 4L generation printer.
Required Supplies:
  • Diffuser panel
  • 3 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Philips scredriver
  • Nitrile gloves
Estimated time: 30 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the diffuser panel.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent cap to prevent resin from dripping off of the bite valves and into the printer.
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the panels of the printer while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the Backlight Unit
Overview: Remove the Backlight Unit to access the diffuser panel.
NOTICE:
Performing maintenance with the Backlight Unit removed increases the risk of contamination inside the optical cavity. Take care to prevent dust or debris from falling inside the printer.
Step 1: Remove the Wi-Fi antenna
Remove the Wi-Fi antenna from the back of the printer and set aside.
Step 2: Position the printer
Ensure that the build platform, resin cartridge, resin tank, and mixer have been removed from the printer to prevent damage. With the help of another person, grip the Form 4L by the bottom front and top rear corners. Carefully rotate the printer so that it is resting on the back surface with the bottom facing you. Leave at least 30 cm (12 in) of clear tabletop in front of the printer when it is lying down.
Step 3: Remove the Backlight Unit screws
Use a 3 mm hex driver to remove the 12 screws that secure the Backlight Unit to the bottom of the printer. Do not remove the Torx screws. Set the screws aside.
Step 4: Separate the Backlight Unit from the printer
Grip the two handles on the Backlight Unit. Carefully pull the Backlight Unit away from the printer and pivot it until it rests on the work surface.
NOTICE:
Take care not to touch the components inside the exposed optical cavity.
Step 5: Unplug the backlight cables
The backlight cables are located at the front of the Backlight Unit. Gently squeeze the plastic tabs to unplug the backlight cables from the Backlight Unit. Do not pull on the individual wires.
Step 6: Unhook the backlight cables
Open the cable management straps and remove the backlight cables.
Step 7: Disconnect the LED fan cables
The LED fan cables are located in the bottom-left of the optical cavity. Squeeze the plastic retaining clips and unplug the LED fan cables from the printer. Do not pull on the wires.
Step 8: Remove the Backlight Unit
Once all the cables are disconnected, remove the Backlight Unit from the printer and set it aside.
Removing the diffuser panel
Overview: After removing the Backlight Unit, remove the diffuser panel.
Step 1: Remove the diffuser panel screws
Form 4L diffuser panel mounting screws
Use a Phillips head screwdriver to remove the nine screws that secure the diffuser panel to the printer. Set the screws aside.
Step 2: Remove the diffuser panel
Remove the diffuser panel from the printer. Set aside for disposal.
Form 4L printer with diffuser panel removed
Take care not to touch the components inside the exposed optical cavity. Doing so may contaminate the LPU and lead to repeated print failures.
Installing the replacement diffuser panel
Overview: Mount and install the replacement diffuser panel.
If the diffuser panel is contaminated during the repair procedure, apply a small amount of clean IPA to a lint-free cloth and wipe the surface of the diffuser panel to remove contamination or resin. Allow the diffuser panel to air dry before installing it.
Step 1: Mount the replacement diffuser panel
Taking care to only handle the diffuser panel at the edges, insert the replacement diffuser panel into the printer. The diffuser panel can only be installed in one orientation. Align the screw holes in the diffuser panel with the screw holes in the printer.
Mounting the Form 4L diffuser panel
Step 2: Secure the replacement diffuser panel
Thread the nine Phillips head screws into the screw holes. Using a Phillips head screwdriver, hand-tighten the nine screws to secure the diffuser panel to the printer. Do not overtighten.
Use care when installing the screws to avoid scratching the diffuser panel. Scratching the diffuser panel may lead to persistent print failures.
Installing the Backlight Unit
Overview: Connect and install the Backlight Unit.
Step 1: Position the Backlight Unit in front of the printer
Place the Backlight Unit on the workspace in front of the printer with the lens array facing up. Orient the Backlight Unit with the backlight cable connectors at the front.
NOTICE:
Do not touch the exposed lenses. Doing so may contaminate the lenses and lead to repeated print failures.
Step 2: Connect the LED fan cables
Connect the LED fan cable connectors to the LED fan cables at the back of the printer. The connectors make an audible and tactile click when secured.
Step 3: Connect the backlight cables
Connect the backlight cables to the Backlight Unit. The connectors make an audible and tactile click when secured.
Step 4: Route the cables
Route the backlight cables along the edge of the Backlight Unit and secure them with the cable management straps.
Step 5: Install the Backlight Unit
Lifting with the two handles, gently slide the Backlight Unit into the printer. Align the pins and screw holes to fully seat the Backlight Unit. Ensure the Backlight Unit is fully seated.
  • Take care not to pinch the wire bundles at the back of the machine.
  • If the Backlight Unit is contaminated during the repair procedure, apply a small amount of clean IPA to a lint-free wipe and wipe the surface of the Backlight Unit to remove contamination or resin. Allow the Backlight Unit to air dry before installing it.
Step 6: Secure the Backlight Unit
Using a 3 mm hex driver, hand tighten the 12 screws on the bottom of the printer to secure the Backlight Unit.
Step 7: Position the printer
With the help of another person, grip the Form 4L by the bottom front and top rear corners. Carefully rotate the printer upright so it sits on its leveling feet.
Step 8: Install the Wi-Fi antenna
Reinstall the Wi-Fi antenna on the back of the printer.
Finalizing the repair
Overview: After securing the Backlight Unit, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Run a test print
Insert any missing consumables and upload and start a print. Perform a small test print to ensure that the printer works normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
