Replacing the Form Cure L V2 motherboard
The Form Cure L V2 motherboard is mounted to the back of the machine’s display assembly. If the motherboard is faulty or malfunctioning, the Form Cure L V2 may behave erratically or not function at all.
Use this guide to replace the motherboard on a Form Cure L V2.
Required Supplies:
Third-party:
  • Phillips driver
  • Nitrile gloves
  • Anti-static grounding strap
Estimated time: 15–20 minutes
Danger:
Preparing the workspace
Overview: Prepare the Form Cure L V2 and workspace for replacing the motherboard.
Step 1: Prepare the workspace
Clear a workspace around your machine. Ensure that the workspace is well-ventilated and free of dust.
Step 2: Unplug the machine
Turn off the machine using the power switch on the back of the unit. Disconnect the power cable before continuing with maintenance. Do not perform maintenance on the machine while it is connected to power. Wait five minutes after disconnecting the machine from power before proceeding. If the machine was recently in use, the post-cure chamber will be warm. Wait at least 10 minutes for the chamber to cool.
Danger:
Performing maintenance on the machine while it is plugged in increases the risk of electric shock. Never remove the machine's shells while it is plugged in. Never reconnect the machine to power while the shells are uninstalled.
Removing the motherboard
Overview: Disconnect and remove the original motherboard.
Step 1: Open the door
Open the curing chamber door to access the screws securing the front panel.
Step 2: Remove the motherboard and display assembly screws
Using a 2 mm hex driver, loosen and remove the four screws securing the motherboard and display assembly to the frame of the machine. Set the screws aside.
Step 3: Unmount the motherboard and display assembly
Gently tilt the motherboard and display assembly upwards then pull it down. The assembly should separate from the machine’s frame. Do not pull sharply on the motherboard and display assembly, as it is still connected to the Form Cure L V2 by a set of cables.
Step 4: Disconnect the motherboard cables
Disconnect all of the cables from the motherboard except for the two ribbon cables. For each, squeeze the tab and slide the cable out of the connector. Take care not to pull on the wires themselves.
Fully separate the motherboard and display assembly from the machine and set it display-side down on your work surface.
Step 5: Uninstall the motherboard
Form Cure L V2 motherboard and display assembly
Form Cure L V2 motherboard and display assembly with ribbon cables disconnected
Disconnect the two ribbon cables from the side of the motherboard. For both, slide the black latch on the cable connector away from the white connector body. Once the latch is open, the ribbon cable should separate from the connector with minimal force. Take care not to fold or otherwise damage the ribbon cables.
Using a Phillips driver, loosen and remove the five screws securing the motherboard to the display assembly. Set the screws aside.
Fully separate the motherboard from the display assembly and set it aside for disposal with electronic waste.
Installing the replacement motherboard
Overview: Connect, mount, and secure the new motherboard.
Step 1: Mount and secure the motherboard
Remove the replacement motherboard from its packaging and place it on the back of the display assembly, aligning the five screw holes in the motherboard with the corresponding screw holes in the display. Thread one motherboard mounting screw into each of the five screw holes, then use a Phillips driver to tighten until snug.
Step 2: Connect the ribbon cables to the motherboard
Form Cure L V2 motherboard and display assembly with ribbon cables onnected
Carefully slide the two ribbon cables into their respective connectors on the motherboard. Push the black latches towards the white connector body. When the latch is flush with the connector body, the ribbon cable is secure.
Step 3: Connect the remaining motherboard cables
Step 1: Connect the motherboard cables
Hold the motherboard and display assembly in front of the machine, near its mounting point. Reconnect all cables to the motherboard, using the image here as a reference. Each cable only fits into its connector in the correct orientation. The locking tab clicks into place when the cable is fully connected.
Step 4: Mount the motherboard and display assembly
Tilt the motherboard and display assembly slightly upwards. Insert it under the front edge of the top shell, then tilt the bottom of the assembly into place. Make sure that it sits flush with the body of the machine and that the four screw holes in the bottom of the motherboard and display assembly align with the corresponding holes in the Form Cure L V2.
Step 5: Secure the motherboard and display assembly
Thread one mounting screw into each of the four screw holes in the bottom of the motherboard and display assembly. Using a 2 mm hex driver, tighten the screws until snug.
Step 3: Secure the motherboard and display assembly
Finalizing the repair
Overview: After installing the new motherboard, perform final checks.
Step 1: Power on the machine
Connect the power cable to the machine and its power supply. Turn on the switch at the back of the machine. Start a post-cure cycle and check that the machine operates normally.
