Schedule of maintenance (Form 3L/Form 3BL)
Proactive maintenance is key for keeping your Form 3L/Form 3BL printing successfully. Consult the table below for a schedule of suggested maintenance procedures and links to additional guides and resources.
For a downloadable resource, see the guide Schedule of maintenance (Form 3L/Form 3BL) (English only).
Daily
ComponentInspectionMaintenance steps
(if problems are noted)
Est TimeIncidentalResource
Build platformInspect the build platform for liquid resin, tackiness, or cured resin on the print surface.Use isopropyl alcohol and paper towels to remove liquid resin or tackiness. Use a paint scraper to remove cured resin.0.1 hPerform this check for each print.SLA basic finishing steps
Monthly
Optical windowRemove the build platform, resin tank, and resin cartridge. On the touchscreen, tap the wrench icon to enter the Settings menu, then tap Maintenance > Motor Moves. The Motor Moves screen appears. Tap and hold Left ( >) to move the LPU housing to the middle of the printer cavity. When the LPU moves to the center, use a light to inspect the optical window for contamination.Remove any contamination using a dry photographic wipe (PEC*PAD) and a rubber bulb blower. If the contamination is difficult to remove, a small amount of isopropyl alcohol (IPA) may be applied to the photographic wipe to aid in removal. The optical glass should be cleaned in a slow, straight wipe from one side to the other. Repeat until all contamination is removed.0.2 hPerform this check when your prints have visual defects, missing features, etc.Maintaining the glass optical window (Form 3L/Form 3BL)
PreFormOpen PreForm and check for version updates. Select Help > About PreForm from the menu bar to check for PreForm updates.If PreForm is unable to connect to the internet, PreForm versions can be downloaded manually using the resource guide provided here.0.1 hPerform this check any time your printer behaves unexpectedly or displays an error message.PreForm downloads and release notes
Printer firmwareOpen PreForm. Expand the right panel by clicking the < button. Click the Printer Name to open the Job Setup window. CSelect the appropriate printer from the list to open the Printer Details window. Click Firmware Update.If the printer is unable to connect to the internet, firmware versions can be downloaded to your computer. Manually downloaded files can be loaded via PreForm in the Firmware Update window.0.1 hPerform this inspection any time your printer behaves unexpectedly or displays an error message.Firmware downloads and release notes
Incidental (as needed)
Print failureThe print fails to adhere to the build platform or parts of the raft are curling off the build platform.
  • Perform an optical window check.
  • Starting a print before it reaches the correct temperature can result in poor adhesion to the build platform—ensure that the printer has reached the correct temperature before printing.
  • In PreForm, using the Slicer tool, check the first layer to ensure your part has good contact with the build platform. In some cases, the raft is too small or narrow for adequate adhesion.
0.5 hPrint fails or partially fails to adhere to the build platform.Non-adherence
LPU housingThe printer makes a clicking sound when the LPU moves all the way to the left side of the resin tank and is picking up or dropping off the mixer.The mixer coupler is rotating too far when trying to engage/disengage the mixer. This does not harm your printer, however if you hear it, contact Formlabs Support or your authorized reseller to schedule a software fix.0.5 hPerform this check when the printer is making unusual noises.Formlabs Support or your authorized reseller
Resin tankThe printer indicates that the resin tank is nearing expiration or has reached the end of its life.Using a resin tank beyond its life expectancy greatly increases the risk of a resin spill. Discontinue use of the resin tank and replace it. Resin can be transferred from the old resin tank to the new one.0.1 hPerform this replacement when prompted by the printer.Resin tank lifetime (Form 3L/Form 3BL)
Resin tankThe printer displays a Mixer Check Failure.This failure typically occurs when cured resin is left on the resin tank or on the build platform. Inspect both and remove any cured resin. If the mixer decouples in a new or unused resin tank, it may help to remove the resin tank and pour resin directly into the tank to add lubrication. If the error persists, replace the resin tank and contact Formlabs Support or your authorized reseller.0.3 hPerform this check when the printer displays a Mixer Check Failure.Form 3L/Form 3BL error messages
Resin cartridgeThe printer has been in the Filling stage for a prolonged period of time but is not dispensing resin.Put on a pair of nitrile gloves, close the vent cap on the resin cartridge, and remove it from the printer. Turn the cartridge over and locate the black rubber bite valve on the bottom of the cartridge. Squeeze the bite valve several times against the hard shell of the cartridge until it unseals and fully opens. If unable to open the bite valve in this way, please contact Formlabs Support or your authorized reseller.0.1 hPerform this check if the printer fails to dispense resin.Resin cartridge maintenance and storage
Resin cartridgeInspect the resin cartridge thoroughly for leakage, especially around the cartridge skirt and the rubber bite valve.Do not use the resin cartridge if you notice resin leakage. Place the resin cartridge in a plastic bag and contact Formlabs Support or your authorized reseller.0.1 hPerform this check before inserting a resin cartridge into the printer.Formlabs Support or your authorized reseller
Resin cartridgeCheck to see if the resin is more than 24 months old. The production date is located on a white sticker on the bottom of the cartridge.Dispose of liquid resin according to environmental regulations.0.1 hPerform this check before inserting a resin cartridge into the printer.Resin care
Resin cartridgeA cartridge is inserted but the touchscreen displays a Cartridge Missing error.Locate the two metal chips on the underside of the resin cartridge and inspect them for damage or contamination. If the chips are intact, clean them with isopropyl alcohol and cotton swabs.0.1 hPerform this check when the corresponding error message is displayed.Resin cartridge maintenance and storage
Roller holderRemove the build platform, resin tank, and resin cartridge. On the touchscreen, tap the wrench icon to enter the Settings menu, then tap Maintenance > Motor Moves. The Motor Moves screen appears. Tap and hold Left ( >) to move the LPU housing to the middle of the printer cavity. When the LPU moves to the center, use a light to inspect the roller holder for contamination.Uninstall the roller holder and remove any contamination using paper towels and photographic wipes (PEC*PADs) dampened with IPA. Follow the instructions in the guide linked in the "Resource" column.0.5 hPerform this check if you experience a resin spill.Cleaning the Form 3L roller holder [EN] [DE] [ES] [FR] [IT] [JA] [ZH]
TouchscreenA resin tank is inserted but the touchscreen displays a Missing Tank error.Test a different resin tank to determine if the issue is related to the original resin tank or the printer. If the issue is related to the original tank, locate the two metal chips on the underside of the resin tank and inspect them for damage or contamination. If the chips are intact, clean them with isopropyl alcohol and cotton swabs. Locate and inspect the spring fingers located against the back wall of the printer cavity on the left side. Clean these with isopropyl alcohol, wiping in the direction of the long axis.0.1 hPerform this check when the corresponding error message is displayed.Maintaining the resin tank (Form 3L/Form 3BL)
Contacting Formlabs Support
If the maintenance steps above do not resolve the issue, contact Formlabs Support or your authorized reseller.
To help us provide the fastest and most effective response to your issue, please follow these steps:
  • Upload diagnostic logs
  • Serial name of the printer
  • Troubleshooting steps attempted
    • Example: “I reoriented the model in PreForm. I inspected the resin tank and did not notice any damage, clouding, or debris.”
  • Resin formulation and lot number
  • Layer thickness
    • Tap Queue on the home screen.
  • Relevant FORM files
    • If available, attach FORM files of the model to the support request.
  • Previous attempts to print the part and any successful prints
    • Example: “I printed the file part2.form three times previously. The first and second were successful. The third one failed.”
