Supporting a model in PreForm
Support structures reinforce overhangs and other delicate features. They should be removed after the print is complete. If a model is entirely self-supporting, then it can be printed directly on the build platform without the need for supports.
Open several files to work on multiple projects in the same job.
Note:
In PreForm 3.51.0, Formlabs introduced a completely revamped support generation workflow that provides a more intuitive and powerful experience, particularly when manually editing supports. For steps specific to earlier versions of PreForm, expand the PreForm 3.50.2 and earlier sections of this article where they appear.
Supporting models
Supports can be auto-generated or added manually. Adding more supports increases the likelihood of print success, but also increases the amount of post-processing work.
  1. Open models in PreForm.
  2. Click Supports. A dialog box opens.
  3. If you have no models selected, click Auto-Generate All. Supports are added to all models on the build platform. Otherwise, if you have one or more models selected, click Auto-Generate Selected. Supports are added to the selected models.
  3. Click Auto-Generate All. Supports are added to all models on the build platform.
Adding supports manually
If some parts of a model are highlighted in red as undersupported, add individual supports:
  1. Select the model in PreForm. Manipulators are overlaid on the model.
  3. Click Touchpoints Placements. The panel expands.
  4. Click Manual Placement. PreForm switches to manual touchpoint placement mode. The model turns gray, and support touchpoints are shown as green dots.
  5. Click on the under-supported areas highlighted in red to add a touchpoint.
  6. Add multiple touchpoints by clicking and dragging your cursor across an under-supported area. Green touchpoints appear where clicked. Use Brush Radius and Spacing tools to change the size of the brush and the spacing between touchpoints.
  7. Click Generate Geometry. Supports are regenerated and remaining undersupported areas are highlighted in red.
    • Click Discard Edits > Discard to revert your changes.
  8. Repeat until the model is fully supported.
  3. Click Edit…. The model turns gray, and support touchpoints are shown as green dots.
  4. Click on the under-supported areas highlighted in red to add a touchpoint.
  5. Add multiple touchpoints by clicking and dragging your cursor across an under-supported area. Green touchpoints appear where clicked. Use Brush Radius and Spacing tools to change the size of the brush and the spacing between touchpoints.
  6. Click Apply. Supports are regenerated and remaining undersupported areas are highlighted in red.
  7. Repeat until the model is fully supported.
Automatically supporting all minima
If you are using PreForm 3.32.0 or later, click Support All Minima when editing supports manually to add touchpoints to all detected minima. Supporting all minima does not generally fully support a model, so you may need to add more supports to make your model printable.
Tip:
PreForm 3.32.0 and later: If you are working with multiple models, click the crosshair icon next to Unsupported Minima Detected to select the model or models with unsupported minima. Click the crosshair icon next to Models Need More Support to select the model or models that are not supported sufficiently.
Removing a touchpoint
To delete a touchpoint:
  5. Click Select & Edit. The supports brush switches modes and the red spacing circle disappears.
  6. Hover over an existing touchpoint with the pointer. The touchpoint turns red.
  7. Click on the red touchpoint. The touchpoint disappears.
  8. Click Generate Structure. Supports are regenerated and the selected touchpoint is removed.
  3. Click Edit…. The model turns gray and supports are shown as green touchpoints.
  4. Hover over an existing touchpoint with the pointer. The touchpoint turns red.
  5. Click on the red touchpoint. The touchpoint disappears. Click and drag on multiple touchpoints to remove them from the model.
  6. Click Apply. Supports are regenerated and the selected touchpoint is removed.
Editing multiple touchpoints at once
Select several touchpoints at a time to apply the same edits to a group. To edit multiple touchpoints:
  6. To select multiple touchpoints, do one of the following:
    • Click-and-drag the pointer to select multiple touchpoints. The selected touchpoints turn blue.
    • Hold the SHIFT key and click multiple touchpoints, one at a time. The selected touchpoints turn blue.
  7. To edit, do one of the following:
    • Enter a number into the Touchpoint Size field.
    • Click an arrow in the Touchpoint Size field.
    • Hover the pointer over the Touchpoint Size field and use the scroll wheel.
  8. To delete, do one of the following:
    • Press the Delete key.
    • Press the Backspace key.
  9. Click Generate Structure. Supports are regenerated.
  4. To select multiple touchpoints, do one of the following:
  5. To edit, do one of the following:
  6. To delete, do one of the following:
  7. Click Apply. Supports are regenerated.
Saving changes
After supporting your model for maximum printability, save your work as a FORM file to keep changes to the support settings.
Supporting models using preset profiles (PreForm 3.51.0–3.59.1)
In PreForm versions from 3.51.0 through 3.59.1, for select resins and layer thicknesses on Form 4 and Form 4L generation printers, you could use alternative support generation presets for more flexibility and control without having to edit advanced parameters. Formlabs removed these presets in PreForm 3.60.0. Users who relied on a specific preset can download them from the tables below. Expand the section for your printer below for a list of download links.
Form 4 generation
A collection of all FPS files is available here.
ResinLayer thicknessFPS files
Black Resin V525 μmReduced Density (v1.0)
Smaller Touchpoints (v1.0)
Supports V2 (v1.0)
Black Resin V550 μmReduced Density (v1.2)
Smaller Touchpoints (v1.2)
Supports V2 (v1.2)
Black Resin V5100 μmReduced Density (v1.2)
Supports V2 (v1.2)
Clear Cast Resin V150 μmReduced Density (v1.0)
Clear Cast Resin V1100 μmReduced Density (v1.0)
Clear Resin V525 μmReduced Density (v1.0)
Supports V2 (v1.0)
Clear Resin V550 μmReduced Density (v1.2)
Supports V2 (v1.2)
Clear Resin V5100 μmReduced Density (v1.2)
Supports V2 (v1.2)
Durable Resin V2.150 μmReduced Density (v1.0)
Durable Resin V2.1100 μmReduced Density (v1.0)
ESD Resin V150 μmReduced Density (v1.0)
ESD Resin V1100 μmReduced Density (v1.0)
Fast Model Resin V1100 μmReduced Density (v1.1)
Smaller Touchpoints (v1.1)
Fast Model Resin V1200 μmReduced Density (v1.1)
Flame Retardant Resin V150 μmReduced Density (v1.0)
Flame Retardant Resin V1100 μmReduced Density (v1.1)
Grey Resin V525 μmReduced Density (v1.0)
Supports V2 (v1.0)
Grey Resin V550 μmReduced Density (v1.2)
Supports V2 (v1.2)
Grey Resin V5100 μmReduced Density (v1.2)
Supports V2 (v1.2)
High Temp Resin V250 μmReduced Density (v1.0)
High Temp Resin V2100 μmReduced Density (v1.0)
Precision Model Resin V125 μmReduced Density (v1.1)
Precision Model Resin V150 μmReduced Density (v1.2)
Precision Model Resin V1100 μmReduced Density (v1.0)
Rigid 10K Resin V1.150 μmReduced Density (v1.0)
Rigid 10K Resin V1.1100 μmReduced Density (v1.0)
Rigid 4000 Resin V150 μmReduced Density (v1.0)
Rigid 4000 Resin V1100 μmReduced Density (v1.0)
Tough 1000 Resin V1100 μmSupports V2 (v1.0)
Tough 1500 Resin V1.150 μmReduced Density (v1.0)
Tough 1500 Resin V1.1100 μmReduced Density (v1.0)
Tough 1500 Resin V250 μmReduced Density (v1.0)
Supports V2 (v1.0)
Tough 1500 Resin V2100 μmReduced Density (v1.1)
Tough 2000 Resin V1.150 μmReduced Density (v1.0)
Supports V2 (v1.0)
Tough 2000 Resin V1.1100 μmReduced Density (v2.0)
Smaller Touchpoints (v2.0)
Supports V2 (v2.0)
White Resin V550 μmReduced Density (v1.2)
Supports V2 (v1.2)
White Resin V5100 μmReduced Density (v1.2)
Supports V2 (v1.2)
Form 4L generation
Supports V2 (v1.0)
Supports V2 (v1.2)
Black Resin V5100 μmReduced Density (v1.0)
Supports V2 (v1.0)
Supports V2 (v1.0)
Supports V2 (v1.2)
Clear Resin V5100 μmReduced Density (v1.0)
Supports V2 (v1.0)
Fast Model Resin V1200 μmReduced Density (v1.0)
Flame Retardant Resin V1100 μmReduced Density (v1.0)
Supports V2 (v1.0)
Supports V2 (v1.2)
Grey Resin V5100 μmReduced Density (v1.0)
Supports V2 (v1.0)
Grey Resin V5150 μmReduced Density (v1.0)
Supports V2 (v1.0)
Precision Model Resin V125 μmReduced Density (v1.0)
Rigid 10K Resin V1.1100 μmReduced Density (v1.1)
Tough 1500 Resin V1.1100 μmReduced Density (v1.1)
Supports V2 (v1.0)
Tough 2000 Resin V1.150 μmReduced Density (v1.1)
Supports V2 (v1.1)
Tough 2000 Resin V1.1100 μmReduced Density (v1.0)
Supports V2 (v1.0)
White Resin V550 μmReduced Density (v1.1)
Supports V2 (v1.1)
White Resin V5100 μmReduced Density (v1.0)
Supports V2 (v1.0)
