What is the largest part I can print on a Formlabs printer?
Form Studio 1
The Form Studio 1 has a build volume of 200 × 125 × 235 mm, or 7.9 × 4.9 × 9.3 inches (5.9 L).
Form 4 and Form 4B
The Form 4 and Form 4B both have a build volume of 200 × 125 × 210 mm, or 7.9 × 4.9 × 8.3 inches (5.2 L).
Check the Form 4 design specifications before designing your part.
Form 4L and Form 4BL
The Form 4L and Form 4BL both have a build volume of 353 × 196 × 350 mm, or 13.9 × 7.7 × 13.8 inches (24.2 L).
Check the Form 4L design specifications before designing your part.
Form 3 and Form 3B
The Form 3 and Form 3B both have a build volume of 145 × 145 × 185 mm, or 5.7 × 5.7 × 7.3 inches.
Check the Form 3 design specifications before designing your part.
Form 3L and Form 3BL
The Form 3L and Form 3BL both have a build volume of 335 × 200 × 300 mm, or 13.2 × 7.9 × 11.8 inches.
Check the Form 3L design specifications before designing your model.
Fuse 1 and Fuse 1+ 30W
Due to varying thermal expansion rates for different materials, the largest parts size printable in the Fuse Series printers varies. The largest part sizes achievable are given in the table below. The maximum achievable dimensions for each material are tuned for each new print setting release, so these dimensions may change over time. The best way to ensure that your part will fit in the build chamber is to test in PreForm.
Material Largest Part Size
Nylon 12 Powder 160.2 × 160.2 × 297.3 mm
Nylon 12 GF Powder 159.9 × 159.9 × 294.1 mm
Nylon 12 Tough Powder 158.8 × 158.8 × 293.5 mm
Nylon 12 White Powder 159.9 × 159.9 × 293.8 mm
Nylon 11 Powder 158.3 × 158.3 × 295.0 mm
Nylon 11 CF Powder 164.6 × 164.6 × 291.7 mm
Nylon 11 Pro Powder 157.7 × 157.7 × 292.5 mm
TPU 90A Powder 161.2 × 161.2 × 295.0 mm
Polypropylene Powder 159.4 × 159.4 × 296.0 mm
Note:
The corners of the Fuse 1 generation build chamber are rounded. In PreForm, the inner radius of the corner is 16 mm. As a result, a square part that fully spans the build chamber in the X and Y directions will not be printable.
Check the design specifications for the Fuse 1 before designing your model.
Fuse X1
Nylon 12 Powder 330 × 330 × 565 mm
