Draining excess resin from the build platform into the resin tank (Form Studio 1)
The Form Studio 1 Build Platform and Build Platform Flex can both hook onto the edge of the printer’s resin tank, allowing you to drain excess resin after a print. This helps save resin and extends the lifetime of your wash solvent.
To drain excess resin from a Form Studio 1 Build Platform after a print:
- Open the printer cover.
- Unlatch and remove the build platform.
- Locate the two notches on the right inner wall of the resin tank.
- Align the top surface of the build platform with the notches and lower it into place.
- Close the printer cover and allow excess liquid resin to drip off the build platform and printed parts back into the resin tank.
- Depending on the viscosity of the resin, letting the build platform drip for 4–5 minutes will drain most of the excess resin back into the resin tank.
Form Studio 1 Build Platform Flex
To drain excess resin from a Form Studio 1 Build Platform Flex after a print:
- Locate the notches on the part release tabs.
- Align the notches with the outer lip of the resin tank and slide the build platform into place.
