Be sure to clean all liquid resin spills with IPA after use.
Supports are necessary for successful SLA printing. Removing the marks and bumps left by supports is an integral step of the finishing process. The Formlabs Finishing Tools kit includes basic supplies for finishing parts printed on Formlabs SLA printers.
After printing, use the Finishing Tools to remove supports and marks during post-processing. The Finishing Tools are an additional supplement to the recommended Formlabs Finish Kits.
Finishing Tools components
Formlabs Finishing Tools help you post-process high-quality finished parts quickly and easily.
Finishing Tools technical specifications
Understand the technical specifications of Formlabs Finishing Tools.
Ergonomic pen sander:
Rotary tool:
Using the Finishing Tools
Power adapter
The power adapter comes with the appropriate electrical plug for your region.
To insert the electrical plug into the adapter:
To remove the plug:
To remove the plug:
Pen sander
The pen sander comes with a variety of bit shapes and adhesive sandpaper.
To prepare the bits:
To insert a bit into the pen sander:
To use the pen sander:
Caution:
The pen sander may become hot after prolonged usage. Take a 10 minute break after every 30 minutes of usage.
Rotary tool
The rotary tool comes with a preinstalled 2.35 mm collet, a 3 mm collet, and a variety of bits.
To insert a bit into the rotary tool:
To change collets:
To use the rotary tool:
Caution:
The rotary tool may become hot after prolonged usage. Take a 10 minute break after every 30 minutes of usage.
Safety resources
Warning:
Orient sharp tools away from yourself, especially when cutting or scraping parts. Take care when using the hobby knife and rotary tool, or when changing rotary tool bits.
Caution:
The rotary tool may damage printed parts if the RPM is set too high.
Post-processing workflow
Use a squirt bottle to rinse parts with IPA or water, or brush parts with a toothbrush to remove dust.
For more information on post-processing, see Removing support marks.
Warranty and replacement parts
Formlabs Finishing Tools include a one-year warranty. For complete details, see the full NA warranty terms or EU warranty terms.
Purchase replacement tools and rotary tool bits from David Union:
Finishing resources
For more information on finishing best practices:
