Tip:
Observe these best practices for washing prints to achieve the cleanest parts.
For Formlabs SLA printers, finishing usually includes the following steps:
Washing—soaking and moving parts in solvent
Isopropyl alcohol (IPA) or tripropylene glycol monomethyl ether (TPM) dissolve liquid resin, making them effective for washing parts printed on Formlabs SLA printers. Two factors—simultaneously soaking and moving parts in solvent—work together to remove the thin layer of liquid resin from the surface of printed parts.
Whether using the Form Wash, Form Wash L, or another washing method, such as the Finish Kit, always consult the support article Form Wash time settings as the primary source of information for up-to-date wash times.
Tip:
Formlabs does not manufacture isopropyl alcohol. Consult the chemical manufacturer or supplier for detailed safety information.
Removing parts from the printer
Always remove the build platform first, then remove the tank, to avoid dripping resin onto the glass optical window or into the printer cavity. Close the cover immediately after removing the platform to prevent ambient light from curing the liquid resin in the resin tank.
Washing parts with the Finish Kit
Follow these basic washing steps and read individual material articles for specific wash instructions. Always consult the support article Form Wash time settings as the primary source of information for up-to-date wash times.
Tip:
When using the Finish Kit with most resins, Formlabs recommends two 10-minute soaks in separate baths, with 30 seconds of movement by hand.
Step 1: Put the build platform on the jig
Place the build platform on the jig included in the Finish Kit.
Form 2
Form 3 generation
Form 3L generation
Step 2: Remove parts from the build platform
To release parts from the build platform, slide a removal tool under the angled edge of the base. Depending on resin type and the geometry of each part, some parts may be easier to remove from the build platform than others.
Tools used to remove parts will scratch the metal surface of the build platform. Scratches are normal and improve part adherence during the initial layers of printing.
Form 2
Form 3 generation
Form 3L generation
Step 3: Move parts in solvent
Form 2
Form 3 generation
Open the first rinse bucket and place the parts in the solvent bath. Use the rinse basket to shake the parts for 30 seconds. This removes liquid resin from the exterior surfaces.
Form 3L generation
Open the rinse bucket and place the parts in the solvent bath. Use the rinse basket to shake the parts for 30 seconds. This removes liquid resin from the exterior surfaces.
Step 4: Soak parts in solvent
Close the rinse bucket lid and let the parts soak for approximately half the total recommended time.
Step 5: Repeat with a second rinse
Form 2
Form 3 generation
Move the parts to the second rinse bucket, then repeat Steps 3 and 4 to move and soak the parts for the remaining time.
Form 3L generation
Repeat Steps 3 and 4 to move and soak the parts for the remaining time.
Tip:
Depending on the concentration of liquid resin in the solvent bath (IPA, TPM), increase the wash time when using the Finish Kit or other manual washing workflows. For smaller parts, reduce the wash time accordingly.
Washing parts with the Form Wash or Form Wash L
The Form Wash and Form Wash L circulate solvent throughout the entire wash cycle, enabling shorter wash times than parts that are left to soak without constant movement.
Depending on the size, leave parts attached to the build platform and follow the detailed Form Wash or Form Wash L workflow. Read individual material articles for specific wash instructions. Always consult the support article Form Wash time settings as the primary source of information for up-to-date wash times.
Cleaning the build platform
Always scrape cured resin off the build platform before reusing it. If the next print uses the same type of resin, there is no need to remove liquid resin. Replace the build platform in the printer and start the next print.
If you are switching resin types, or if you do not plan to reuse the build platform right away, clean the build platform with IPA and paper towels to thoroughly remove liquid resin from the build surface and edges. Liquid resin cures in ambient light, and resin left on the surface of a build platform renders it unusable.
Drying
Always let prints fully dry (whether they have been washed in IPA, TPM, or water) before post-curing or post-processing. Forced air, such as a fan or clean compressed air may dry parts more quickly.
For volatile solvents such as IPA, allow parts to dry for at least 30 minutes after washing to allow the solvent to fully evaporate from part surfaces. Ensure appropriate ventilation while the solvent evaporates.
For solvents that do not readily evaporate, such as TPM, let parts drip dry thoroughly and then rinse in water or IPA until all remaining TPM has dissolved.
Post-curing
Post-curing is optional for standard resins. Other resin types require post-curing to achieve their optimal mechanical properties.
Always consult the support article Form Cure time and temperature settings as the primary source of information for up-to-date post-cure settings.
Tip:
Observe these best practices for post-curing prints to help parts achieve their optimal mechanical properties.
Removing supports
Formlabs recommends removing supports after post-curing, since parts may warp under exposure to light and heat without structural support.
Use the flush cutters included in the Finish Kit to carefully cut the supports attached to the parts. You may also use a scalpel or hobby knife to remove supports.
For parts with complex or delicate geometries, refer to the support article Advanced support removal.
Caution:
Some methods of support removal may cause small pieces of supports to break away. Beware of flying debris and consider wearing eye protection and gloves to protect the skin and eyes.
Sanding, priming, and painting parts (optional)
After removing supports, remove support marks by dry sanding or wet sanding. Depending on the part’s application and desired finish, further post-processing steps may include priming and painting prints.
