Setting up a network connection for the Fuse X1
Connect the Fuse X1 to a secure network via Ethernet or Wi-Fi (with a dongle), providing it internet access for remote printing, remote troubleshooting, sending diagnostic logs, and receiving firmware updates. The Fuse X1 can connect directly to a computer with a USB cable.
For remote printing and monitoring, the Fuse X1 supports both wired (Ethernet) and wireless (Wi-Fi) connections. Connect PreForm print preparation software to the same local-area network (LAN) as the printer in order to send a print job.
When the Fuse X1 is connected to a LAN, its current status and print progress can be monitored with Dashboard: formlabs.com/dashboard.
Connecting with Ethernet
The rear of the unit is equipped with a RJ-45 Ethernet (10BASE-T/100BASE-TX) 100 Mbit LAN Port. Use a shielded Ethernet cable (not included), minimum Cat5.
To connect with Ethernet:
Plug one end of the Ethernet cable into the Ethernet port on the back of the unit.
Connect the other end of the Ethernet cable to your LAN.
Connecting with a manual IP configuration
When connected to an active Ethernet connection, the Fuse X1 can be configured with a static IP address. Use the touchscreen to configure a manual IP connection.
To connect with Ethernet using a manual IP configuration:
With an established Ethernet connection, tap the gear icon on the Home screen. The Settings screen appears.
Tap Connectivity. The Connectivity screen appears.
For Ethernet connections, tap Ethernet. The Manual IP Settings screen appears.
Toggle Use Manual IP to ON. The toggle turns blue.
Enter the appropriate IP Address, Subnet Mask, Default Gateway, and Name Server.
Connecting with Wi-Fi
The Fuse X1 can connect to a Wi-Fi network via a Wi-Fi dongle plugged into the USB A port on the rear of the machine. For best performance, Formlabs recommends connecting via Ethernet or USB.
