Bucket not detected (Form Wash L)
Explanation
The error message Bucket not detected indicates that the Form Wash L limit switch was unable to detect the wash bucket. If the limit switch is malfunctioning or the wash bucket is damaged or deformed, the Form Wash L may not be able to operate properly.
Causes
  • Malfunctioning limit switch
  • Damaged or deformed wash bucket
Symptoms
  • Form Wash L displays error message Bucket not detected
Troubleshooting steps
  1. Update the Form Wash L firmware.
  2. Inspect the wash bucket for damage.
    1. Tap Raise. The platform mount rises out of the wash bucket.
    2. Open the Form Wash L door.
    3. Disconnect the solvent monitor from the Form Wash L. Twist the plug collar counterclockwise and pull the plug away from the machine.
    4. Gently pull the wash bucket towards you to remove it from the Form Wash L.
    5. Inspect the rear of the wash bucket for damage or deformation.
    6. Take photos of any damage.
  3. Inspect the limit switch for damage. It is located to the right of the platform mount at the base of the unit. Clean it with a dampened paper towel if it is contaminated with solvent or resin. Take photos of any damage.
  1. While wearing gloves, press and hold the limit switch by hand. The Form Wash L beeps when a functioning limit switch is engaged.
  2. Reinsert the wash bucket. Push the wash bucket in until it reaches the back wall of the unit.
  3. Plug the solvent monitor into the socket on the front of the unit. The Form Wash L beeps when the wash bucket is successfully inserted.
  4. If the issue persists, contact Formlabs Support or your authorized reseller. Include the Form Wash L diagnostic logs with other relevant observations and details to speed up resolution.
