Note:
If you have the 4 mm nozzle orifice installed on the Fuse Blast, follow the instructions in the support article Replacing the Fuse Blast blast orifice to install the 3 mm one.
The Fuse Blast Polishing System is a module you can install on your Fuse Blast to provide additional polishing for SLS printed parts.
Installing the Polishing Module
Installing the injection nozzle
Note:
Installing the Fuse Blast Polishing Mesh
Before filling the machine with Formlabs Polishing Media, install the Fuse Blast Polishing Mesh.
Preparing the Fuse Blast and polishing media
If the Fuse Blast has been used previously with non-polishing media, you must empty the media hopper before adding Fuse Blast Polishing Media. Likewise, if you would like to put glass media in the Fuse Blast, follow the instructions in the support article Switching blasting media types.
Updating the Fuse Blast firmware
The Fuse Blast Polishing System needs to be enabled on the Fuse Blast touchscreen. Update your machine’s firmware to ensure it is compatible with the Polishing System.
Enabling the Polishing System and preparing it for use
Before you polish your printed parts, enable the Polishing System and prime the water line:
