Tip:
If you are shipping the printer, review its shipping weight and dimensions.
Clean the printer and reuse the original packaging to prepare the printer for shipping or transit.
Tip:
Required resources
The original packaging is designed to be kept and reused for transporting or shipping the machine for service. Save the complete packaging including any inserts for your convenience.
Made by Formlabs:
Made by third parties:
Preparing for transportation
Before repackaging, remove the build chamber and optical cassette. Vacuum the print enclosure and air filters, then empty the printer's hopper.
Caution:
A Fuse 1 generation printer is a heavy object. A two person lift is required to prevent injury and avoid damage to the machine.
To prepare the printer:
Packaging
Thoroughly read and follow the instructions to properly package the machine. Skipping any of the following steps may result in shipping damage and void the warranty.
To package the machine:
Do not tilt the machine when placing the lifting straps. Doing so may damage the print enclosure door or cause the machine to topple over.
Caution:
A Fuse 1 generation printer is a heavy object. Use appropriate precautions and correct lifting form when moving the machine.
