Insert washed and dried prints
Allow parts to fully dry after washing. Check surfaces and interior spaces for trapped solvent. Curing parts that contain solvent and dissolved resin may cure solvent inside the part, prevent parts from strengthening, and affect material properties.
Open the door and distribute parts on the round turntable. Space parts evenly to allow light and heat to reach all areas. Close the door.
Set the post-cure time and temperature
- Check your resin’s recommended post-cure time and temperature before beginning a post-cure cycle.
- Turn the knob to navigate the display menu and select the material type and version. Push the knob to select or confirm.
- Select Start. The LEDs activate, and the timer starts once the heater reaches the target temperature.
During preheating, the display shows the Preheating status, which includes the current temperature and the target temperature.
