Formlabs recommends a manual cleaning cycle for removing powder from tight corners, large interior cavities, or parts too large to tumble effectively. There are two options for manually cleaning parts in the Fuse Blast:
- Assisted manual cleaning: With the blast gun mounted on the blast arm in the active position, point the blast nozzle down towards the grate and manipulate the part with both hands.
- Hand-held manual cleaning: With the blast arm in the idle position, hold the blast gun with one hand and the part in the other hand.
For best results, disable the polishing toggle while using a manual cycle on the Fuse Blast. High flow rates may result in visibly wet parts, causing dust to stick to the surface of the printed part and prevent good quality results.
The blast gun mounts directly on the blast arm. To remove the blast gun for hand-held manual blasting, slide the blast gun directly up and off the blast arm. To mount the blast gun, slide the blast gun onto the blast arm.
After extracting printed parts from the powder cake with the Fuse Sift, clean and media blast printed parts with the Fuse Blast’s manual cleaning mode:
