Disposing of Formlabs packaging
This article provides guidance on how to responsibly dispose of packaging materials for Formlabs consumables.
Note:
These recommendations are valid under the assumption that packaging materials are free of resin and nylon powder.
Definitions
Household waste
Household waste is waste that is not recyclable, compostable, biodegradable, or hazardous.
  • Do not pour liquid or partially cured resin into drains or dispose of it with household waste.
  • Do not pour solvent (IPA, TPM) that contains dissolved resin into drains or dispose of it with household waste. Safe and appropriate disposal methods of used solvent vary by location.
  • For disposal purposes, vacuum bags and filters used to clean unsintered powder should be considered unsintered powder waste.
Stickers and tape
The recyclability of materials is not affected by the presence of stickers or tape. Stickers are burned off of plastics and become caught in pulp straining films during cardboard recycling.
Expanded polystyrene (EPS)
USA
There may be a dedicated expanded polystyrene (EPS) recycler in your region, but otherwise this material is non-recyclable by most community recycling centers unless otherwise specified.
Resin cartridge packaging (Form 4 and Form 4L)
A cartridge box, made of corrugated cardboard, with a plastic bag, made of polypropylene
Cardboard box
  • Material: Recycled cardboard
  • Recommendation: Recyclable, curbside collection
Clear plastic cartridge bag
  • Material: Polypropylene (PP)
A resin cartridge, made of polyethylene, polypropylene, and silicone rubber
  • Material: Blow molded polyethylene, silicone rubber, polypropylene, and polyethylene foam
  • Recommendation: Refer to the support article Disposing of resin cartridges for guidance on cartridge disposal. The intricate internal geometry of Formlabs cartridges necessitates specific disposal measures.
Resin cartridge packaging (Form 2, Form 3, and Form 3L)
Cardboard box
  • Material: Corrugated cardboard
A clear plastic cartridge bag, made of 100% virgin polyethylene
  • Material: 100% virgin polyethylene (PE) film
  • Recommendation: Recyclable at some facilities
A resin cartridge, made of high-density polyethylene and polypropylene
Cartridge body and skirt
  • Material: High-density polyethylene (HDPE) and polypropylene (PP)
A cartridge foam pad, made of polyethylene
Foam pad
  • Material: Polyethylene (PE) foam
  • Recommendation: Household waste
A bite valve cover, made of polyethylene terephthalate
Bite valve cover
  • Material: Polyethylene terephthalate (PET)
  • Recommendation: Recyclable, curbside collection if free of resin
    • If coated with resin, cure resin with UV light (365 nm and 395 nm) or sunlight and dispose of it as household waste.
Cartridge packaging for Formlabs resins for biocompatible applications
A booklet, made of matte coated art paper
Instructions for use booklet
  • Material: Matte coated art paper
Form 4 generation resin tank packaging
A Form 4 resin tank box, made of cardboard
Resin tank box
  • Material: Cardboard
A Form 4 resin tank bag, made of polypropylene
Resin tank bag
A Form 4 resin tank cover, made of polypropylene
Resin tank cover
A Form 4 mixer, made of polyamide, polypropylene, stainless steel, carbon steel, and aluminum
Mixer
  • Material: Polyamide, polypropylene, stainless steel, carbon steel, and aluminum
A Form 4 mixer box, made of cardboard
Mixer box
Form 4L generation resin tank packaging
A Form 4L resin tank box, made of cardboard
Resin tank box
A Form 4L resin tank bag, made of polypropylene
Resin tank bag
A Form 4L resin tank cover, made of polypropylene
Resin tank cover
Mixer
  • Material: A Form 4L mixer, made of polyamide, polypropylene, stainless steel, carbon steel, and aluminum
Mixer box
Form 3/Form 3B resin tank packaging
A Form 3/Form 3B cartridge box, made of 3-mm-thick cardboard
Cardboard box (V1)
  • Material: Cardboard, 3 mm
A Form 3/Form 3B cartridge box, made of 3-mm-thick cardboard, with a PET window
Cardboard box (V2)
  • Material: Cardboard, 3 mm, with PET window
A Form 3/Form 3B mixer sleeve, made of polyethylene film
Mixer sleeve
  • Material: Polyethylene film
A Form 3/Form 3B tank frame foarm, made of polyurethane
Tank frame foam
  • Material: Polyurethane (PU) foam
Form 3/Form 3B mixer retention foam, made of polyurethane foam
Mixer retention foam
  • Material: Polyurethane foam
A Form 3/Form 3B tank case, made of black polypropylene
Tank case V1
Tip:
Save the tank case and tank case lid to store your resin tanks between prints.
A Form 3/Form 3B tank box insert, made of polypropylene
Tank case V2
Tip:
For newer resin tanks, the shipping box also acts as the tank case. Save the box and included tray to store your resin tanks between prints.
A Form 3/Form 3B tank case lid, made of amber-tinted plastic
Tank case lid
  • Material: Plastic
    • If coated with resin, cure resin with UV light (365 nm and 395 nm) or sunlight before disposal.
Tip:
Mixer retention block
  • Material: Expanded polyethylene (EPE) foam, corrugated cardboard
  • Recommendation: Household waste (USA) or recyclable, curbside collection (other countries, depending on local regulations)
Form 3L/Form 3BL resin tank packaging
A Form 3L/Form 3BL tank box, made of 3-mm-thick cardboard
Cardboard box
A Form 3L/Form 3BL tank case, made of double gray cardboard and glossy coated art paper
Tank case
  • Material: Double gray cardboard and glossy coated art paper
Tip:
Save the tank case and tank case tray to store your resin tanks between prints.
A Form 3/Form 3BL tank case tray, made of polypropylene
Tank case tray
Tip:
Clear film from a Form 3L/Form 3BL tank case, made of polyethylene film and ethylene vinyl acetate film
Clear case film
  • Material: Polyethylene film and ethylene vinyl acetate film
Note:
The EPE foam and corrugated cardboard are adhered to one another and are hard to separate.
A Form 3/Form 3BL tank case inner padding, made of expanded polyethylene foam
Tank case inner padding
Fuse 1 powder packaging
A Fuse 1 power cartridge box, made of corrugated cardboard
Cardboard box
A Fuse 1 powder credit card on backing, made of matte art paper and polyvinyl chloride
Powder credit card on backing
  • Material: Matte art paper and polyvinyl chloride (PVC)
  • Recommendation:
    • Backing: Recyclable, curbside collection
    • Card: Household waste
A Fuse 1 powder jug, made of high-density polyethylene
Powder jug
  • Recommendation: Retain for later powder storage. High-density polyethylene is recyclable but this item should be treated as contaminated with/containing powder. Refer to the support article Powder care, storage, and disposal for guidance on HDPE disposal.
A Fuse 1 powder bag, made of aluminum-lined plastic
Powder bag
  • Material: Aluminum-lined plastic
  • Recommendation: Powder bags are not recyclable and should be treated as contaminated with or containing powder. For guidance on powder container disposal, refer to the support article Powder care, storage, and disposal.
Form 4 generation build platform packaging
A Form 4 Build Platform box, made of cardboard
Cardboard box
Form 4 Build Platform Flex padding, made of expanded polyethylene foam
Foam (Build Platform Flex only)
Informational insert (Build Platform Flex only)
  • Material: Paper
Form 4L generation build platform packaging
  • Material: Paper
Form 2 and Form 3/Form 3B build platform packaging
A build platform box for the Form 2/Form 3/Form 3B, made of corrugated cardboard
Cardboard box
Form 3L/Form 3BL build platform packaging
A build platform box for the Form 3L/Form 3BL, made of corrugated cardboard
Cardboard box
Black foam padding for the Form 3L/Form 3BL build platform box, made of expanded polystyrene foam
Foam padding
  • Material: Expanded polystyrene (EPS) foam
